Ana içeriğe geç
Disassembling Logitech M305 Wireless mouse
Neye ihtiyacın var
  1. Disassembling Logitech M305 Wireless mouse, Logitech M305 Wireless mouse: adım 1, 1 resimden 1.
    • M305 Wireless mouse
    FixBot'a Sor
    Yorum Ekle
  2. Disassembling Logitech M305 Wireless mouse: adım 2, 1 resimden 1.
    • Turn mouse over to reveal the battery cover removal button.
    FixBot'a Sor
    Yorum Ekle
  3. Disassembling Logitech M305 Wireless mouse: adım 3, 1 resimden 1.
    • Slide the button back and then release in over to remove battery cover on the top of mouse.
    FixBot'a Sor
    Yorum Ekle
  4. Disassembling Logitech M305 Wireless mouse: adım 4, 1 resimden 1.
    • Remove small top access screw.
    FixBot'a Sor
    Yorum Ekle
  5. Disassembling Logitech M305 Wireless mouse: adım 5, 1 resimden 1.
    • Remove (gently) sticky pads with the spudger or a sharp knife/cutter.
    FixBot'a Sor
    Yorum Ekle
  6. Disassembling Logitech M305 Wireless mouse: adım 6, 1 resimden 1.
    • After removing all four sticky pads, unscrew the four screws. One screw for each hole.
    FixBot'a Sor
    Yorum Ekle
  7. Disassembling Logitech M305 Wireless mouse: adım 7, 1 resimden 1.
    • Once screws are removed, the top comes off, but be careful not to pull too hard because of the attached wires.
    FixBot'a Sor
    Yorum Ekle
  8. Disassembling Logitech M305 Wireless mouse: adım 8, 1 resimden 1.
    • Battery Contact on the rear of mouse. There is a black plastic tab that holds the battery contact. The red arrow is pointing to it. Look at image #10 (last image) and use the same instructions with this battery contact and black plastic tab as with the other battery contact.
    FixBot'a Sor
    Yorum Ekle
  9. Disassembling Logitech M305 Wireless mouse: adım 9, 1 resimden 1.
    • Battery contact on front of mouse (while the mouse cover is upside down). The red arrow is pointing to the black plastic tab holding the battery contact.
    FixBot'a Sor
    Yorum Ekle
  10. Disassembling Logitech M305 Wireless mouse: adım 10, 1 resimden 1.
    • Tool is being used to pry the battery contact away from the black plastic tab. (please excuse the rough looking tool i used). Once the contact is pried away then take a pair of needle nose pliers and pull the battery contact straight up. You may have to wiggle the pliers some as you pull up.
    FixBot'a Sor
    Yorum Ekle
Sonuç
18 farklı kişi bu kılavuzu tamamladı.
Darren
609 İtibar
1 Kılavuz yazıldı
21Kılavuz Yorumları
Oh, bless. You enabled me to revive my M305! Its mouse wheel had ceased to scroll reliably. Following your instructions, I was able to clean out all the accumulated dust and hair and lint that was getting in the way, and now it works like new.
I would add just one more step: There is a screw towards the front of the mouse which holds the wheel down. Remove that, lift out the entire wheel unit, and then you can get at any built-up yuck that was trapped between the wheel and the board.
vortexae - Yanıt Paylaş
Ok thank you. I will look into that.
Darren - Yanıt Paylaş
I am so glad that this project helped you so much. I will add that next step and thank you for telling me about it. I am planning on adding more in the future. If there is something that you would like to see on here, just comment here and I will see if I can do it or have the item here.
Thanks again.
I've found the answer! How to separate out the on-off switch:
The circuit board is fixed to the base/bottom of the mouse by one silver screw in the center--you can see the screw clearly in the last photo Darren posted. Remove that screw, and lift out the circuit board. Since the on-off switch is just sandwiched between the circuit board and the mouse's base, it will fall out freely as you do this.
one additional thing that's nifty is to get rid of the spin wheel "click." to do this, once it's guts are exposed, take off the wheel mount, remove the wheel from the mount, and stick a small flat head screw driver in the open side to pry out the spinning part. a small ball bearing will fall out - that's what creates the friction and the "click" when you spin the wheel. now put everything back together and presto! smooth wheeling!
Adam Pyburn - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 24
Son 30 gün: 94
Her zaman: 27,158
