Ana içeriğe geç
Disassembling Logitech MBJ58 Mouse Scroll wheel from mount
Neye ihtiyacın var
  1. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Top cover: adım 1, 1 resimden 1.
    • Hold the mouse so that the bottom is facing up.
    • Remove the single Phillips #1 screw from the bottom half of the mouse.
  2. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: adım 2, 2 resimden 1. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: adım 2, 2 resimden 2.
    • Place the mouse so that the bottom is resting against a hard surface.
    • Lift the top cover of the mouse gently, and remove it.
  3. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: adım 3, 3 resimden 1. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: adım 3, 3 resimden 2. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: adım 3, 3 resimden 3.
    • Locate the scroll wheel on the mouse.
    • Grab the scroll wheel with your thumb and index finger.
    • Gently lift up, to remove the scroll wheel from the mouse.
  4. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Support Spring: adım 4, 2 resimden 1. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Support Spring: adım 4, 2 resimden 2.
    • Locate the spring on the scroll wheel, and carefully remove the spring.
  5. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Attaching the New Spring: adım 5, 2 resimden 1. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Attaching the New Spring: adım 5, 2 resimden 2.
    • Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
  6. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: adım 6, 3 resimden 1. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: adım 6, 3 resimden 2. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: adım 6, 3 resimden 3.
    • Use the images to locate where the resistance spring is.
    • This spring will easily fall off.
    • Grab the scroll wheel and its mount and gently pull them apart.
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Maximilian Betkowski
238 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-14, Forte Winter 2013 Cal Poly, Team 5-14, Forte Winter 2013 üyesi
CPSU-FORTE-W13S5G14
5 Üyeler
23 adet Kılavuz yazıldı
7Kılavuz Yorumları
Excellent! I took an MBJ58 apart to remove accumulated gunk, and the resistance spring jumped onto my worktable before I noticed where it came from. Thanks for the help, well done!
Marty Swartz - Yanıt
Heh, me too. Couldn't for the life of me figure out how it went back in. Thanks for the guide!
Steve Bennett - Yanıt
Same thing happened to me...saved me a trip to the store for a new mouse!!
thanks for taking the time to post these photos!
Bill McFarland - Yanıt
huh, thank you very much, amazing guide, the only for this product in Internet , and amazingly accurate
leartzajmi - Yanıt
the resistence spring falled off on mine how do i out it back on help
Tay Carr - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 69
Her zaman: 8,287
