Giriş
The Macintosh IIsi came with a red-ribbon 1.44MB "SuperDrive" (and yes, just like DVD-Burning "SuperDrives" this was the best available option)
Parçalar
Hiçbir parçaya gerek yok.
  1. Start by turning the computer around, and remove this #0 Phillips Screw.
    • Start by turning the computer around, and remove this #0 Phillips Screw.
    • There may or may not be a Phillips #0 screw here, depending on whether or not the computer has ever been serviced.
  2. Now lift these two clips, and slowly pivot the case up.
    • Now lift these two clips, and slowly pivot the case up.
    • You can now seperate the top of the computer from the rest of the machine.
    • The "SuperDrive" is mounted similarly to the hard drive, and positioned right next to it.
    • Push these two tabs out, and lift the drive up.
    • Flip the drive so it is on top of the power supply, and remove the "Red-Ribbon" cable.
    • 1.44MB floppy drives need a ribbon cable with a red stripe on one side. 400KB floppy drives use a ribbon cable with a yellow stripe on one side. 800KB floppy drives can use a red, or yellow striped cable.
    • This drive was manufactured by Sony in 1990.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Chris Green
32.753 İtibar
45 adet Kılavuz yazıldı
Takım
Master Techs Master Techs üyesi
Community
279 Üyeler
769 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 3
Her zaman: 2,443
