Giriş
The Macintosh IIsi Uses a 120/240V AC Power Supply. It provides power directly to the logic board. From there, it is distributed to the rest of the computer.
Aletler
Parçalar
Hiçbir parçaya gerek yok.
The "SuperDrive" is mounted similarly to the hard drive, and positioned right next to it.
Push these two tabs out, and lift the drive up.
The fan recieves power from two contacts on the logic board and has no connector.
In all of the years that I have worked on this machine, I have found no good way to remove the fan.
The best way to start, is to push in here on the side of the fan.
Being careful not to exert too much force, try to push in, and wiggle the fan outward as such. (2nd Photo)
You can now lift the fan all the way out, and remove it.
The Fan Power Contacts on the Logic Board:
To remove the power supply, squeeze these two tabs and lift the front up.
On the back of the power supply, there is a tab that also must be pressed to remove the power supply fully. You can then lift it out all the way. A firm tug may be necessary to seperate the power connector.
