Ana içeriğe geç
Disassembling Marshall MS-2 Micro Amp Case Disassembly
Neye ihtiyacın var
  1. Disassembling Marshall MS-2 Micro Amp Case Disassembly, Disassembling Marshall MS-2 Micro Amp Case Disassembly: adım 1, 1 resimden 1.
    • First be sure to turn the power switch to the off position.
    • Do this by turning the leftmost knob counter-clockwise as until the line points to "off."
  2. Disassembling Marshall MS-2 Micro Amp Case Disassembly: adım 2, 3 resimden 1. Disassembling Marshall MS-2 Micro Amp Case Disassembly: adım 2, 3 resimden 2. Disassembling Marshall MS-2 Micro Amp Case Disassembly: adım 2, 3 resimden 3.
    • Now remove the battery.
    • On the back of the device locate the battery cover.
    • Remove it by pushing down on the clip.
    • Then pull the piece of fabric until the battery comes out.
  3. Disassembling Marshall MS-2 Micro Amp Case Disassembly: adım 3, 2 resimden 1. Disassembling Marshall MS-2 Micro Amp Case Disassembly: adım 3, 2 resimden 2.
    • Use the long, skinny phillips head screwdriver to remove the 4 7/16" screws on the back of the device in the four corners.
    • Once unscrewed, do not try to take each screw out. Move to next step once all screwed have been unscrewed.
  4. Disassembling Marshall MS-2 Micro Amp Case Disassembly: adım 4, 1 resimden 1.
    • Now pull the back panel off and place it down as shown. Pull the panel straight up so you do not lose the screws.
Sonuç
Bir başkası bu kılavuzu tamamladı.
MacKinley
811 İtibar
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 2,083
