Ana içeriğe geç
Disassembling Marshall MS-2 Partner Circuit Board
Neye ihtiyacın var
  1. Disassembling Marshall MS-2 Partner Circuit Board, Disassembling Marshall MS-2 Micro Amp Case Disassembly: adım 1, 1 resimden 1.
    • First be sure to turn the power switch to the off position.
    • Do this by turning the leftmost knob counter-clockwise as until the line points to "off."
  2. Disassembling Marshall MS-2 Partner Circuit Board: adım 2, 3 resimden 1. Disassembling Marshall MS-2 Partner Circuit Board: adım 2, 3 resimden 2. Disassembling Marshall MS-2 Partner Circuit Board: adım 2, 3 resimden 3.
    • Now remove the battery.
    • On the back of the device locate the battery cover.
    • Remove it by pushing down on the clip.
    • Then pull the piece of fabric until the battery comes out.
  3. Disassembling Marshall MS-2 Partner Circuit Board: adım 3, 2 resimden 1. Disassembling Marshall MS-2 Partner Circuit Board: adım 3, 2 resimden 2.
    • Use the long, skinny phillips head screwdriver to remove the 4 7/16" screws on the back of the device in the four corners.
    • Once unscrewed, do not try to take each screw out. Move to next step once all screwed have been unscrewed.
  4. Disassembling Marshall MS-2 Partner Circuit Board: adım 4, 1 resimden 1.
    • Now pull the back panel off and place it down as shown. Pull the panel straight up so you do not lose the screws.
  5. Disassembling Marshall MS-2 Partner Circuit Board, Partner Circuit Board: adım 5, 2 resimden 1. Disassembling Marshall MS-2 Partner Circuit Board, Partner Circuit Board: adım 5, 2 resimden 2.
    • Use a 9/16" socket to remove the nut around the headphone jack. Be careful to not lose the washer.
  6. Disassembling Marshall MS-2 Partner Circuit Board: adım 6, 1 resimden 1.
    • Remove the 7/16" phillips head screw.
  7. Disassembling Marshall MS-2 Partner Circuit Board: adım 7, 1 resimden 1.
    • Grab the headphone jack from inside the case and pull it toward the speaker until you can fully remove it from the device.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
MacKinley
811 İtibar
5 adet Kılavuz yazıldı
Bir Yorum
There Is a toroidal transformer inside ?
Jack redmond - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 14
Her zaman: 1,863
