Ana içeriğe geç
Disassembling Mercedes W123 Glove Box Liner
Neye ihtiyacın var
  1. Disassembling Mercedes W123 Glove Box Liner, Glove Box Liner: adım 1, 1 resimden 1.
    • Start by opening the glove box.
  2. Disassembling Mercedes W123 Glove Box Liner: adım 2, 2 resimden 1. Disassembling Mercedes W123 Glove Box Liner: adım 2, 2 resimden 2.
    • Remove the two phillips screws in the glove box door catch, then remove it.
  3. Disassembling Mercedes W123 Glove Box Liner: adım 3, 2 resimden 1. Disassembling Mercedes W123 Glove Box Liner: adım 3, 2 resimden 2.
    • Gently pry apart the expansion plug in the glove box clips. There will be a row of them on top, and on the bottom.
    • Once you've pried it out part of the way you can pull it the rest of the way out by hand, or gently with needle nose pliers.
  4. Disassembling Mercedes W123 Glove Box Liner: adım 4, 1 resimden 1.
    • You can then pry the clips out of the liner. Remove them all.
  5. Disassembling Mercedes W123 Glove Box Liner: adım 5, 1 resimden 1.
    • Gently pry down the cover for the glove box lamp.
  6. Disassembling Mercedes W123 Glove Box Liner: adım 6, 1 resimden 1.
    • Now unplug the two connections from the lamp and remove the lamp housing.
    • Be sure to make note of the orientation of the two wires for re-installation.
  7. Disassembling Mercedes W123 Glove Box Liner: adım 7, 1 resimden 1.
    • Now the glove box liner will pull out by hand.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Nicolas Siemsen
39.040 İtibar
79 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.535 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 64
Her zaman: 11,097
