Ana içeriğe geç
Disassembling Midland X-tra Talk Radio LXT118 Speaker
Neye ihtiyacın var
  1. Disassembling Midland X-tra Talk Radio LXT118 Speaker, Batteries: adım 1, 2 resimden 1. Disassembling Midland X-tra Talk Radio LXT118 Speaker, Batteries: adım 1, 2 resimden 2.
    • First, apply pressure with your thumb on the top of the battery cover.
    • Next, pull down on the cover until it begins to slide.
  2. Disassembling Midland X-tra Talk Radio LXT118 Speaker: adım 2, 1 resimden 1.
    • Finally, once the cover is completely off, pry up the old batteries with your finger or a strong, skinny tool (i.e. spudger).
  3. Disassembling Midland X-tra Talk Radio LXT118 Speaker, Case: adım 3, 1 resimden 1.
    • Unscrew the six 8.0 millimeter long, #0 screws on the backside of the case using the Phillips #0 screwdriver.
  4. Disassembling Midland X-tra Talk Radio LXT118 Speaker: adım 4, 1 resimden 1.
    • Detach back part of the case by gently lifting up.
  5. Disassembling Midland X-tra Talk Radio LXT118 Speaker, Speaker: adım 5, 1 resimden 1.
    • Remove the circuit board from the front part of the radio case.
    • Clip the red and black connecting wires at the base closest to the circuit bored in the spots denoted by the two red circles.
  6. Disassembling Midland X-tra Talk Radio LXT118 Speaker: adım 6, 1 resimden 1.
    • Scrape off the glue on the outer lining of the speaker using the metal spudger.
  7. Disassembling Midland X-tra Talk Radio LXT118 Speaker: adım 7, 1 resimden 1.
    • Pry the speaker from the case using the metal spudger.
    • This should not take excessive force, so make sure all remaining glue is scraped off from the edges if it will not easily come out.
  8. Disassembling Midland X-tra Talk Radio LXT118 Speaker: adım 8, 1 resimden 1.
    • The speaker is now disassembled!
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
James Tucker Dunn
371 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 19-43, Regan Winter 2013 Cal Poly, Team 19-43, Regan Winter 2013 üyesi
CPSU-REGAN-W13S19G43
3 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 14
Her zaman: 590
