Ana içeriğe geç
Disassembling Minolta Maxxum STsi Top Cover
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. Disassembling Minolta Maxxum STsi Top Cover, Main Battery: adım 1, 1 resimden 1.
    • Use the edge of a coin to twist open the battery compartment on the bottom of the camera. (Twist counterclockwise)
  2. Disassembling Minolta Maxxum STsi Top Cover: adım 2, 1 resimden 1.
    • When the compartment opens, pull the AA battery out of its slot.
  3. Disassembling Minolta Maxxum STsi Top Cover, Top Cover: adım 3, 1 resimden 1.
    • Remove the black Phillips #00 5mm screw at the bottom of the battery chamber.
    • If it is too dark to see the screw, it may help to use a flashlight.
  4. Disassembling Minolta Maxxum STsi Top Cover: adım 4, 1 resimden 1.
    • Take out two silver Phillips #00 5.0 mm screws on each side of the viewfinder.
  5. Disassembling Minolta Maxxum STsi Top Cover: adım 5, 1 resimden 1.
    • Open the flash and take out the silver Phillips #00 4.0 mm screw underneath it.
  6. Disassembling Minolta Maxxum STsi Top Cover: adım 6, 1 resimden 1.
    • Open the back-cover of the camera using the back-cover release found on the lower right side of the camera.
  7. Disassembling Minolta Maxxum STsi Top Cover: adım 7, 1 resimden 1.
    • Remove the black Phillips #00 4.0 mm screw from the inside top right section of the camera.
  8. Disassembling Minolta Maxxum STsi Top Cover: adım 8, 1 resimden 1.
    • Remove the black Phillips #00 5.0 mm screw from the back of the film compartment.
  9. Disassembling Minolta Maxxum STsi Top Cover: adım 9, 2 resimden 1. Disassembling Minolta Maxxum STsi Top Cover: adım 9, 2 resimden 2.
    • Remove the seven black Phillips #00 5.0 mm screws from the bottom panel. The bottom panel is now free to come off.
  10. Disassembling Minolta Maxxum STsi Top Cover: adım 10, 1 resimden 1.
    • Take out two black Phillips #00 2.5 mm screws on the right side panel of the camera.
  11. Disassembling Minolta Maxxum STsi Top Cover: adım 11, 3 resimden 1. Disassembling Minolta Maxxum STsi Top Cover: adım 11, 3 resimden 2. Disassembling Minolta Maxxum STsi Top Cover: adım 11, 3 resimden 3.
    • Starting beneath the "SPOT" button, use the round side of the metal spudger and firmly pry underneath the grey top panel of the camera. Work your way counterclockwise around the camera prying at different spots until the top panel starts to come loose. Pry all the way around until you reach the "STsi" logo.
    • This prying will not completely release the top cover. It is also necessary to take off the side panel, as explained in the next step.
  12. Disassembling Minolta Maxxum STsi Top Cover: adım 12, 2 resimden 1. Disassembling Minolta Maxxum STsi Top Cover: adım 12, 2 resimden 2.
    • Be careful when removing the right side panel. There is a plastic component underneath the side panel that will come free. Note the orientation of this plastic component for reassembly because it is connected to the back-cover release switch.
    • Also be gentle when removing the top panel because it is delicate and is connected by wires.
    • Carefully remove the right side panel by grasping it at the bottom and rotating is counter-clockwise. The top panel is now free to snap off.
Sonuç
Brady Hill
234 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-12, Amido Spring 2015 Cal Poly, Team 14-12, Amido Spring 2015 üyesi
CPSU-AMIDO-S15S14G12
3 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 81
