Ana içeriğe geç
Disassembling Motorola i850 Keypad
Neye ihtiyacın var
  1. Disassembling Motorola i850 Keypad, Disassembling Motorola i850 Back Cover: adım 1, 1 resimden 1.
    • Use your thumb to slide the back cover locker away from the antenna.
  2. Disassembling Motorola i850 Keypad: adım 2, 2 resimden 1. Disassembling Motorola i850 Keypad: adım 2, 2 resimden 2.
    • Slide the back cover towards the antenna while lifting the cover away from the phone.
  3. Disassembling Motorola i850 Keypad, Battery: adım 3, 1 resimden 1.
    • Place your thumb on the indicated corner while stabilizing the phone and the upper portion of the battery with your forefinger.
  4. Disassembling Motorola i850 Keypad: adım 4, 2 resimden 1. Disassembling Motorola i850 Keypad: adım 4, 2 resimden 2.
    • Lift the battery out of the phone while pushing it towards the antenna.
  5. Disassembling Motorola i850 Keypad, Keypad: adım 5, 1 resimden 1.
    • Once battery is removed, untighten the screws located near the edges of the device with a Phillips #00 Screwdriver.
  6. Disassembling Motorola i850 Keypad: adım 6, 3 resimden 1. Disassembling Motorola i850 Keypad: adım 6, 3 resimden 2. Disassembling Motorola i850 Keypad: adım 6, 3 resimden 3.
    • Grip the device firmly with both hands and carefully open the device.
    • Warning: Be incredibly careful removing the back panel as you may tear the flex cable connecting the loudspeaker and side buttons.
  7. Disassembling Motorola i850 Keypad: adım 7, 2 resimden 1. Disassembling Motorola i850 Keypad: adım 7, 2 resimden 2.
    • Carefully remove the hardware by gripping the side of the hardware attachment with a tweezer.
  8. Disassembling Motorola i850 Keypad: adım 8, 2 resimden 1. Disassembling Motorola i850 Keypad: adım 8, 2 resimden 2.
    • Carefully grip the side of the hardware attachment with a tweezer and detach from device.
  9. Disassembling Motorola i850 Keypad: adım 9, 3 resimden 1. Disassembling Motorola i850 Keypad: adım 9, 3 resimden 2. Disassembling Motorola i850 Keypad: adım 9, 3 resimden 3.
    • Place the back of the device on your hand and flip it over with the other hand.
    • Carefully lift the device to remove interior hardware.
    • The structure of the keypad should easily be loose from flipping the device.
  10. Disassembling Motorola i850 Keypad: adım 10, 3 resimden 1. Disassembling Motorola i850 Keypad: adım 10, 3 resimden 2. Disassembling Motorola i850 Keypad: adım 10, 3 resimden 3.
    • Carefully remove the keypad by griping on the side of the plastic with a tweezer.
    • WARNING: The plastic keypad is sensitive and can be easily damaged.
Sonuç
Tony Chen
1 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 34-56, Forte Spring 2010 Cal Poly, Team 34-56, Forte Spring 2010 üyesi
CPSU-FORTE-S10S34G56
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 40
Her zaman: 1,870
