Ana içeriğe geç
Disassembling Motorola i90c Keypad
Neye ihtiyacın var
    1. Disassembling Motorola i90c Keypad, Battery: adım 1, 3 resimden 1. Disassembling Motorola i90c Keypad, Battery: adım 1, 3 resimden 2. Disassembling Motorola i90c Keypad, Battery: adım 1, 3 resimden 3.
      • Slide the notch downward while pulling the back cover off to remove it.
      FixBot'a Sor
      Yorum Ekle
    2. Disassembling Motorola i90c Keypad: adım 2, 3 resimden 1. Disassembling Motorola i90c Keypad: adım 2, 3 resimden 2. Disassembling Motorola i90c Keypad: adım 2, 3 resimden 3.
      • Use your fingers to push the battery upward from the bottom.
      • Lift upwards to remove the battery.
      FixBot'a Sor
      Yorum Ekle
    1. Disassembling Motorola i90c Keypad, Antenna: adım 3, 2 resimden 1. Disassembling Motorola i90c Keypad, Antenna: adım 3, 2 resimden 2.
      • Unscrew the antenna in a counter-clockwise fashion.
      • Remove the aluminum cover.
      FixBot'a Sor
      Yorum Ekle
    1. Disassembling Motorola i90c Keypad, Midframe: adım 4, 3 resimden 1. Disassembling Motorola i90c Keypad, Midframe: adım 4, 3 resimden 2. Disassembling Motorola i90c Keypad, Midframe: adım 4, 3 resimden 3.
      • Unscrew the 3 screws shown.
      • Lift the right part of the Nextel logo
      • Remove the screw underneath.
      FixBot'a Sor
      Yorum Ekle
    2. Disassembling Motorola i90c Keypad: adım 5, 2 resimden 1. Disassembling Motorola i90c Keypad: adım 5, 2 resimden 2.
      • Forcing the cover off could damage the ribbon cable, so be careful when doing so.
      • Gently lift the back cover off.
      FixBot'a Sor
      Yorum Ekle
    3. Disassembling Motorola i90c Keypad: adım 6, 3 resimden 1. Disassembling Motorola i90c Keypad: adım 6, 3 resimden 2. Disassembling Motorola i90c Keypad: adım 6, 3 resimden 3.
      • Find the connection between the headphone jack and logic board.
      • Begin separating the two pieces, slowly and carefully.
      FixBot'a Sor
      Yorum Ekle
    1. Disassembling Motorola i90c Keypad, Logic Board: adım 7, 2 resimden 1. Disassembling Motorola i90c Keypad, Logic Board: adım 7, 2 resimden 2.
      • Lift the first logic board off of the rest of the device.
      FixBot'a Sor
      Yorum Ekle
    2. Disassembling Motorola i90c Keypad: adım 8, 1 resimden 1.
      • Gently lift the second logic board from the rest of the device.
      • DO NOT force the board straight off as it could damage the ribbon cable!
      FixBot'a Sor
      Yorum Ekle
    3. Disassembling Motorola i90c Keypad: adım 9, 2 resimden 1. Disassembling Motorola i90c Keypad: adım 9, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Using tweezers, carefully pull off the connector shown.
      FixBot'a Sor
      Yorum Ekle
    1. Disassembling Motorola i90c Keypad, Keypad: adım 10, 3 resimden 1. Disassembling Motorola i90c Keypad, Keypad: adım 10, 3 resimden 2. Disassembling Motorola i90c Keypad, Keypad: adım 10, 3 resimden 3.
      • Remove the keypad buttons off the front cover of the phone.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Jorge
4 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 29-61, Johann Spring 2010 Cal Poly, Team 29-61, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S29G61
4 Üyeler
48 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 3
Son 30 gün: 27
Her zaman: 1,728
