Ana içeriğe geç
Disassembling Motorola i90c Logic Board
Neye ihtiyacın var
  1. Disassembling Motorola i90c Logic Board, Battery: adım 1, 3 resimden 1. Disassembling Motorola i90c Logic Board, Battery: adım 1, 3 resimden 2. Disassembling Motorola i90c Logic Board, Battery: adım 1, 3 resimden 3.
    • Slide the notch downward while pulling the back cover off to remove it.
  2. Disassembling Motorola i90c Logic Board: adım 2, 3 resimden 1. Disassembling Motorola i90c Logic Board: adım 2, 3 resimden 2. Disassembling Motorola i90c Logic Board: adım 2, 3 resimden 3.
    • Use your fingers to push the battery upward from the bottom.
    • Lift upwards to remove the battery.
  3. Disassembling Motorola i90c Logic Board, Antenna: adım 3, 2 resimden 1. Disassembling Motorola i90c Logic Board, Antenna: adım 3, 2 resimden 2.
    • Unscrew the antenna in a counter-clockwise fashion.
    • Remove the aluminum cover.
  4. Disassembling Motorola i90c Logic Board, Midframe: adım 4, 3 resimden 1. Disassembling Motorola i90c Logic Board, Midframe: adım 4, 3 resimden 2. Disassembling Motorola i90c Logic Board, Midframe: adım 4, 3 resimden 3.
    • Unscrew the 3 screws shown.
    • Lift the right part of the Nextel logo
    • Remove the screw underneath.
  5. Disassembling Motorola i90c Logic Board: adım 5, 2 resimden 1. Disassembling Motorola i90c Logic Board: adım 5, 2 resimden 2.
    • Forcing the cover off could damage the ribbon cable, so be careful when doing so.
    • Gently lift the back cover off.
  6. Disassembling Motorola i90c Logic Board: adım 6, 3 resimden 1. Disassembling Motorola i90c Logic Board: adım 6, 3 resimden 2. Disassembling Motorola i90c Logic Board: adım 6, 3 resimden 3.
    • Find the connection between the headphone jack and logic board.
    • Begin separating the two pieces, slowly and carefully.
  7. Disassembling Motorola i90c Logic Board, Logic Board: adım 7, 2 resimden 1. Disassembling Motorola i90c Logic Board, Logic Board: adım 7, 2 resimden 2.
    • Lift the first logic board off of the rest of the device.
  8. Disassembling Motorola i90c Logic Board: adım 8, 1 resimden 1.
    • Gently lift the second logic board from the rest of the device.
    • DO NOT force the board straight off as it could damage the ribbon cable!
  9. Disassembling Motorola i90c Logic Board: adım 9, 2 resimden 1. Disassembling Motorola i90c Logic Board: adım 9, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using tweezers, carefully pull off the connector shown.
Sonuç
Grant Glazebrook
7 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 29-61, Johann Spring 2010 Cal Poly, Team 29-61, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S29G61
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 1,055
