Ana içeriğe geç
Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700
Neye ihtiyacın var
  1. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700, Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: adım 1, 2 resimden 1. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700, Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: adım 1, 2 resimden 2.
    • Unplug the USB cord from the top of the mouse.
  2. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: adım 2, 3 resimden 1. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: adım 2, 3 resimden 2. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: adım 2, 3 resimden 3.
    • Power off the mouse. The power switch is located on the bottom of the mouse above the battery.
  3. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: adım 3, 3 resimden 1. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: adım 3, 3 resimden 2. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: adım 3, 3 resimden 3.
    • Remove the battery as illustrated in the images.
  4. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: adım 4, 3 resimden 1. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: adım 4, 3 resimden 2. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: adım 4, 3 resimden 3.
    • Peel off the four sticker pads located on the bottom of the mouse. They will be on the top, bottom and sides.
    • Stick these pads onto a clean, flat surface for safe keeping as you continue to disassemble the mouse.
  5. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: adım 5, 2 resimden 1. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: adım 5, 2 resimden 2.
    • Locate and remove the five screws that were hidden under the sticker pads.
  6. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: adım 6, 2 resimden 1. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: adım 6, 2 resimden 2.
    • Carefully pry off the top of the mouse. This will remove the housing from the circuit board.
  7. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: adım 7, 3 resimden 1. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: adım 7, 3 resimden 2. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: adım 7, 3 resimden 3.
    • Gently detach the four wires from the holder of the housing.
    • View: Underneath housing
  8. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: adım 8, 2 resimden 1. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: adım 8, 2 resimden 2.
    • Remove the seven screws that hold the top housing, middle housing, and side keys together.
    • If disassembling for cleaning purposes, you need only to remove the four screws near the bottom in order to remove the top cover alone.
  9. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: adım 9, 3 resimden 1. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: adım 9, 3 resimden 2. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: adım 9, 3 resimden 3.
    • Press the side keys toward the bottom of the housing.
    • This will detach the keys and wires from the housing.
  10. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: adım 10, 3 resimden 1. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: adım 10, 3 resimden 2. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: adım 10, 3 resimden 3.
    • Gently pry the lock holding both mouse buttons.
    • View: Underneath housing (still one piece)
  11. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: adım 11, 3 resimden 1. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: adım 11, 3 resimden 2. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: adım 11, 3 resimden 3.
    • Gently pry away the upper part of the housing.
    • View: Housing divided into two pieces: top and middle
  12. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: adım 12, 1 resimden 1.
    • Unscrew the two screws holding the part that locks the function buttons.
    • View: Underneath middle housing
  13. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: adım 13, 2 resimden 1. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: adım 13, 2 resimden 2.
    • Slowly remove the plastic part you just unscrewed.
  14. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: adım 14, 1 resimden 1.
    • Carefully pull each button towards you.
    • Do not misplace the small springs attached to the buttons.
  15. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: adım 15, 2 resimden 1. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: adım 15, 2 resimden 2.
    • Congratulations! You are now able to clean the mouse.
    • Be careful when reinstalling the screws. Due to their small size, they strip the sockets easily if overtightened.
Sonuç
34 farklı kişi bu kılavuzu tamamladı.
Tomasz
879 İtibar
1 Kılavuz yazıldı
7 Yorum
Exactly what I was looking for. Guide worked perfectly. Thanks!
oscarsdg1 - Yanıt
I need the clear image of components on the main board. Could you please help me? Do you have any image of components on the main board?
Thanks
Hupaa - Yanıt
Thanks!! I got my mouse working again.
sm3333 - Yanıt
Thanks! i got my mouse working again thanks to this article.
sm3333 - Yanıt
I did open my mouse to clean but I open the wheel too. Inside are to support torqued springs that I do not know how to put them back. in this case my mouse wheel is not working properly. Can you please help me with some pictures or an advice?
Hellyworld - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 27
Son 30 gün: 132
Her zaman: 49,836
