Ana içeriğe geç
Disassembling Mouse Rapoo MT760 Pro
Neye ihtiyacın var
  1. Disassembling Mouse Rapoo MT760 Pro, Remove Skates: adım 1, 3 resimden 1. Disassembling Mouse Rapoo MT760 Pro, Remove Skates: adım 1, 3 resimden 2. Disassembling Mouse Rapoo MT760 Pro, Remove Skates: adım 1, 3 resimden 3.
    • There are four screws hidden under the back two skates. You do not need to remove the front one. I used a razor blade to carefully lift the pads without touching the adhesive too much. If they get dirty, you may need to replace them.
    • There are two #1 Phillips screws under the main pad and two #0 Phillips screws under the thumb wing.
    FixBot'a Sor
    Yorum Ekle
  2. Disassembling Mouse Rapoo MT760 Pro: adım 2, 3 resimden 1. Disassembling Mouse Rapoo MT760 Pro: adım 2, 3 resimden 2. Disassembling Mouse Rapoo MT760 Pro: adım 2, 3 resimden 3.
    • The back is now loose. Carefully start to pry it open, using a thin spudger or plastic card to the clips on the front.
    • There is one clip on near the USB-C port.
    • There are two clips just in front of the thumb. These are difficult to remove and require pulling the vertical silver piece out while slipping the bottom down.
    FixBot'a Sor
    Yorum Ekle
  3. Disassembling Mouse Rapoo MT760 Pro: adım 3, 3 resimden 1. Disassembling Mouse Rapoo MT760 Pro: adım 3, 3 resimden 2. Disassembling Mouse Rapoo MT760 Pro: adım 3, 3 resimden 3.
    • Open the mouse carefully to avoid damaging the ribbon cable.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Be sure to keep your mouse skates clean or you may have to replace them.
Steven Williams
98 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 29
Son 30 gün: 173
Her zaman: 577
