Ana içeriğe geç
Disassembling NEC LCD1770NX Monitor Enclosure
Neye ihtiyacın var
  1. Disassembling NEC LCD1770NX Monitor Enclosure, Stand: adım 1, 2 resimden 1. Disassembling NEC LCD1770NX Monitor Enclosure, Stand: adım 1, 2 resimden 2.
    • Place the monitor face down on a clean, flat surface.
  2. Disassembling NEC LCD1770NX Monitor Enclosure: adım 2, 2 resimden 1. Disassembling NEC LCD1770NX Monitor Enclosure: adım 2, 2 resimden 2.
    • Firmly remove the back panel of the stand by pulling it up and away from the monitor.
  3. Disassembling NEC LCD1770NX Monitor Enclosure: adım 3, 2 resimden 1. Disassembling NEC LCD1770NX Monitor Enclosure: adım 3, 2 resimden 2.
    • Unscrew the two 6mm Phillips PH2 screws to detach the stand enclosure from the stand.
  4. Disassembling NEC LCD1770NX Monitor Enclosure: adım 4, 2 resimden 1. Disassembling NEC LCD1770NX Monitor Enclosure: adım 4, 2 resimden 2.
    • Firmly grasp the stand enclosure with your hand and slide it to base of stand.
  5. Disassembling NEC LCD1770NX Monitor Enclosure: adım 5, 1 resimden 1.
    • Unscrew the two 14.5mm Phillips PH2 screws holding the stand to the monitor.
  6. Disassembling NEC LCD1770NX Monitor Enclosure: adım 6, 2 resimden 1. Disassembling NEC LCD1770NX Monitor Enclosure: adım 6, 2 resimden 2.
    • Lift the the stand straight up to remove it.
  7. Disassembling NEC LCD1770NX Monitor Enclosure, Monitor Enclosure: adım 7, 3 resimden 1. Disassembling NEC LCD1770NX Monitor Enclosure, Monitor Enclosure: adım 7, 3 resimden 2. Disassembling NEC LCD1770NX Monitor Enclosure, Monitor Enclosure: adım 7, 3 resimden 3.
    • Place the monitor screen face up.
    • Pull the frame off by placing your fingers on the inside of the frame and pulling out and up, the frame should snap off.
    • Continue your way around the screen.
  8. Disassembling NEC LCD1770NX Monitor Enclosure: adım 8, 3 resimden 1. Disassembling NEC LCD1770NX Monitor Enclosure: adım 8, 3 resimden 2. Disassembling NEC LCD1770NX Monitor Enclosure: adım 8, 3 resimden 3.
    • Unscrew the two 7mm screws from the bottom of the button assembly.
    • Do not pull the button assembly out too quickly or with too much force! Damage to the wires can occur.
    • Pull the button assembly out a few inches and unplug the colored cables.
  9. Disassembling NEC LCD1770NX Monitor Enclosure: adım 9, 2 resimden 1. Disassembling NEC LCD1770NX Monitor Enclosure: adım 9, 2 resimden 2.
    • Unscrew the gold colored 7mm Phillips PH000 screw holding the button assembly to the monitor.
    • Remove the button assembly from the monitor.
  10. Disassembling NEC LCD1770NX Monitor Enclosure: adım 10, 1 resimden 1.
    • With the monitor face-down, unscrew the 5 7mm Phillips PH2 screws around the outside of the enclosure.
  11. Disassembling NEC LCD1770NX Monitor Enclosure: adım 11, 3 resimden 1. Disassembling NEC LCD1770NX Monitor Enclosure: adım 11, 3 resimden 2. Disassembling NEC LCD1770NX Monitor Enclosure: adım 11, 3 resimden 3.
    • Unscrew the 2 14.5mm Phillips PH2 screws located on the raised center of the enclosure.
    • Carefully pull the enclosure off the monitor.
  12. Disassembling NEC LCD1770NX Monitor Enclosure: adım 12, 2 resimden 1. Disassembling NEC LCD1770NX Monitor Enclosure: adım 12, 2 resimden 2.
    • Unscrew the 10 5mm Philips PH2 screws holding the metal casing to the monitor.
  13. Disassembling NEC LCD1770NX Monitor Enclosure: adım 13, 2 resimden 1. Disassembling NEC LCD1770NX Monitor Enclosure: adım 13, 2 resimden 2.
    • Pull the the metal casing off of the monitor to reveal the motherboards.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
John Patterson
271 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 11-36, Amido Fall 2013 Cal Poly, Team 11-36, Amido Fall 2013 üyesi
CPSU-AMIDO-F13S11G36
5 Üyeler
7 adet Kılavuz yazıldı
1Rehber Yorum
very helpful
Thank you
Richard Morgan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 28
Her zaman: 6,263
