Ana içeriğe geç
Disassembling NEC LCD1770NX Stand
Neye ihtiyacın var
  1. Disassembling NEC LCD1770NX Stand, Stand: adım 1, 2 resimden 1. Disassembling NEC LCD1770NX Stand, Stand: adım 1, 2 resimden 2.
    • Place the monitor face down on a clean, flat surface.
  2. Disassembling NEC LCD1770NX Stand: adım 2, 2 resimden 1. Disassembling NEC LCD1770NX Stand: adım 2, 2 resimden 2.
    • Firmly remove the back panel of the stand by pulling it up and away from the monitor.
  3. Disassembling NEC LCD1770NX Stand: adım 3, 2 resimden 1. Disassembling NEC LCD1770NX Stand: adım 3, 2 resimden 2.
    • Unscrew the two 6mm Phillips PH2 screws to detach the stand enclosure from the stand.
  4. Disassembling NEC LCD1770NX Stand: adım 4, 2 resimden 1. Disassembling NEC LCD1770NX Stand: adım 4, 2 resimden 2.
    • Firmly grasp the stand enclosure with your hand and slide it to base of stand.
  5. Disassembling NEC LCD1770NX Stand: adım 5, 1 resimden 1.
    • Unscrew the two 14.5mm Phillips PH2 screws holding the stand to the monitor.
  6. Disassembling NEC LCD1770NX Stand: adım 6, 2 resimden 1. Disassembling NEC LCD1770NX Stand: adım 6, 2 resimden 2.
    • Lift the the stand straight up to remove it.
Sonuç
Michela Upson
110 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 11-36, Amido Fall 2013 Cal Poly, Team 11-36, Amido Fall 2013 üyesi
CPSU-AMIDO-F13S11G36
5 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 1,244
