Ana içeriğe geç
Disassembling Nerf Recon CS-6 Shell
Neye ihtiyacın var
  1. Disassembling Nerf Recon CS-6 Shell, Remove Magazine: adım 1, 1 resimden 1.
    • Skip this step if magazine is already removed.
    • Pull slide back.
    • Pull backwards on release buttons and slide magazine out.
    • Push slide back forward and pull trigger.
    FixBot'a Sor
    Yorum Ekle
  2. Disassembling Nerf Recon CS-6 Shell, Remove Visible Screws: adım 2, 1 resimden 1.
    • Use the Phillips #0 Screwdriver to remove these 9 screws.
    • All screws marked in red are 9.6 mm Phillips #0 screws.
    • Note that left most screw is longer than the rest and is a 18.6 mm Phillips #0 screw.
    FixBot'a Sor
    Yorum Ekle
  3. Disassembling Nerf Recon CS-6 Shell, Remove Hidden Screws: adım 3, 2 resimden 1. Disassembling Nerf Recon CS-6 Shell, Remove Hidden Screws: adım 3, 2 resimden 2.
    • Pull slide back to reveal more screws.
    • Remove these 2 screws.
    • Push slide forward.
    • Pull trigger to release compression of the main spring.
    • Screws are 9.6 mm Phillips #0.
    • Pulling the trigger will keep spring from launching out of the gun when the two halves are separated.
    FixBot'a Sor
    Yorum Ekle
  4. Disassembling Nerf Recon CS-6 Shell, Remove Plunger Cap: adım 4, 1 resimden 1.
    • Remove the screws on the plunger cap.
    • Tug the plunger cap off.
    FixBot'a Sor
    Yorum Ekle
  5. Disassembling Nerf Recon CS-6 Shell, Remove Slide Screws: adım 5, 1 resimden 1.
    • Remove the 2 screws on the slide.
    • Hold the two halves of the gun together to prevent any springs from launching out.
    FixBot'a Sor
    Yorum Ekle
  6. Disassembling Nerf Recon CS-6 Shell, Split the Gun in Half: adım 6, 2 resimden 1. Disassembling Nerf Recon CS-6 Shell, Split the Gun in Half: adım 6, 2 resimden 2.
    • Pull the gun apart at the middle seam.
    • Watch for any springs that might launch out.
    FixBot'a Sor
    Yorum Ekle
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Asad Qureshi
595 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team 8-14, Williams Fall 2014 Baylor, Team 8-14, Williams Fall 2014 üyesi
BU-WILLIAMS-F14S8G14
3 Üyeler
6 adet Kılavuz yazıldı
2Kılavuz Yorumları
Does anyone have a spare spring for this gun I am missing mine
The Lazy Gamer - Yanıt Paylaş
very useful, thanks!
Sebastian Isaacs - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 53
Her zaman: 12,853
