1. Remove the screws from the bottom, right, and left side of camera.
    • Remove the screws from the bottom, right, and left side of camera.
  2. Remove the back of the camera, may require force.
    • Remove the back of the camera, may require force.
    • Unscrew the right metal bracket of the viewing lens
    • Unscrew the top right corner screw
    • Unscrew the bottom right corner screw.
    • Pull the grey circular facet that sits on the bottom outside of the camera off - may have to use force.
    • Pull the front of the camera off of the mother board.
    • Unscrew the grey plastic around the screen
    • Twist the grey bracket counterclockwise to remove it from the silver LCD bracket.
    • Maneuver to detach the flash bulb.
    • Unscrew the metal bracket under the lens
    • Slide the plastic bracket through the metal bracket.
    • Remove the orange cable from the motherboard.
    • Pull the black tape off.
    • Unscrew the two screws underneath.
    • Remove lens
Sonuç
Bir başkası bu kılavuzu tamamladı.
Crista Riedy
406 İtibar
3 adet Kılavuz yazıldı
Takım
Ohio State, Team 1-2, Buehl Spring 2013 Ohio State, Team 1-2, Buehl Spring 2013 üyesi
OSU-BUEHL-S13S1G2
2 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 2
Her zaman: 524
