Giriş
This guide has been updated by iFixit staff! Read the new, official guide here.
This guide will show you how to remove the lower screen.
Neye ihtiyacın var
Place your device upside down and locate the battery compartment.
Find the Phillips head screw securing the battery cover in the bottom right hand corner of the device.
Remove the following seven screws that secure the lower case to the DS Lite:
Three silver tri-wing screws (5mm long)
One black tri-wing screw (4mm)
Two gold Phillips screws (4mm)
One silver Phillips screw (3mm)
Do not remove the silver PH screw (3mm) in the battery compartment yet. It holds the main PCB in place.
Flip the unit over so that it is facing right-side up.
Use a spudger to pry open the gap between the bottom case and the front panel. Work all the way around the case until the panel is free.
Avoid touching the L and R shoulder buttons, because they easily detach and are difficult to reassemble. Keep the bottom case flat against your workbench to help hold the shoulder buttons in place.
Remove the two screws holding the motherboard to the rest of the device using a Phillips #00 screwdriver.
6 farklı kişi bu kılavuzu tamamladı.
