Ana içeriğe geç
Disassembling Nokia 1100b RH-36
Neye ihtiyacın var
  1. Disassembling Nokia 1100b RH-36, Battery Cover: adım 1, 2 resimden 1. Disassembling Nokia 1100b RH-36, Battery Cover: adım 1, 2 resimden 2.
    • Flip the phone over so that the screen faces down.
    • Press the gray button on the battery cover and slide it down off the back of the phone.
  2. Disassembling Nokia 1100b RH-36, Battery: adım 2, 1 resimden 1.
    • Wedge the flat end of the spudger into the small indent next to the Nokia logo on the battery.
    • Gently pry the battery out of the phone.
  3. Disassembling Nokia 1100b RH-36, Front Cover: adım 3, 2 resimden 1. Disassembling Nokia 1100b RH-36, Front Cover: adım 3, 2 resimden 2.
    • Firmly grip the back of the casing.
    • Separate the front and back casings either by pulling them apart from the middle or gently prying the front off with your fingers from the bottom.
    • Be sure not to bend the casing too much when prying from the bottom. Failure to do so may cause it to crack.
  4. Disassembling Nokia 1100b RH-36, Inner Casing: adım 4, 2 resimden 1. Disassembling Nokia 1100b RH-36, Inner Casing: adım 4, 2 resimden 2.
    • Remove the six 6mm T6 Torx screws around the edge of the front of the phone.
    • Remove the metal frame holding the screen and speaker.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
JSwan
805 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-43, Amido Spring 2013 Cal Poly, Team 10-43, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S10G43
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 2,563
