Ana içeriğe geç
Disassembling Nokia 1110i (RH-93) made in Hongrie
Neye ihtiyacın var
  1. Disassembling Nokia 1110i (RH-93) made in Hongrie, Disassembling Nokia 1110i (RH-93) made in Hongrie: adım 1, 3 resimden 1. Disassembling Nokia 1110i (RH-93) made in Hongrie, Disassembling Nokia 1110i (RH-93) made in Hongrie: adım 1, 3 resimden 2. Disassembling Nokia 1110i (RH-93) made in Hongrie, Disassembling Nokia 1110i (RH-93) made in Hongrie: adım 1, 3 resimden 3.
    • Switch off the device to avoid shocks while disassembling.
    • Turn the device face down and press on the small button at the bottom . Slide the back case down.
    • To remove the battery, use your finger to insert it in the groove and pull the battery out.
  2. Disassembling Nokia 1110i (RH-93) made in Hongrie: adım 2, 3 resimden 1. Disassembling Nokia 1110i (RH-93) made in Hongrie: adım 2, 3 resimden 2. Disassembling Nokia 1110i (RH-93) made in Hongrie: adım 2, 3 resimden 3.
    • To remove the protective cover, use the tool shown and press the grey button at the left bottom.
    • The front cover ejects as shown. Remove it carefully to avoid damage.
    • The keypad case can be removed easily. Pull it up off the device.
    • Use a T6 Torx screwdriver to remove the screws.
  3. Disassembling Nokia 1110i (RH-93) made in Hongrie: adım 3, 3 resimden 1. Disassembling Nokia 1110i (RH-93) made in Hongrie: adım 3, 3 resimden 2. Disassembling Nokia 1110i (RH-93) made in Hongrie: adım 3, 3 resimden 3.
    • Find this channel at the top of your device.
    • Use a pair of tweezers to remove it carefully without harming the surroundings.
    • Insert the spudger into the section to remove the module.
  4. Disassembling Nokia 1110i (RH-93) made in Hongrie: adım 4, 2 resimden 1. Disassembling Nokia 1110i (RH-93) made in Hongrie: adım 4, 2 resimden 2.
    • Use the spudger to remove the module casing safely.
    • Your device is successfully disassembled.
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
JDU TV
3.063 İtibar
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 11
Her zaman: 3,592
