Ana içeriğe geç
Disassembling Nokia 2366i Front Cover
Neye ihtiyacın var
  1. Disassembling Nokia 2366i Front Cover, Battery: adım 1, 2 resimden 1. Disassembling Nokia 2366i Front Cover, Battery: adım 1, 2 resimden 2.
    • Turn off the phone.
    • Position the phone so that the back side is in view.
  2. Disassembling Nokia 2366i Front Cover: adım 2, 1 resimden 1.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    • Remove the back battery cover.
  3. Disassembling Nokia 2366i Front Cover: adım 3, 3 resimden 1. Disassembling Nokia 2366i Front Cover: adım 3, 3 resimden 2. Disassembling Nokia 2366i Front Cover: adım 3, 3 resimden 3.
    • Insert the spudger between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • Carefully lift the battery out of the phone.
    • The battery lifts out of the phone easily.
  4. Disassembling Nokia 2366i Front Cover, Front Cover: adım 4, 1 resimden 1.
    • Keep the phone closed.
    • Hold the phones sideways with the front cover of the phone facing up.
  5. Disassembling Nokia 2366i Front Cover: adım 5, 2 resimden 1. Disassembling Nokia 2366i Front Cover: adım 5, 2 resimden 2.
    • Find the slight crease on the side that divides the display assembly in half.
    • Slowly wedge the spudger into the crease.
    • It's a little difficult to perform this step because the crease is narrow. Do not rush because you may damage the phone
  6. Disassembling Nokia 2366i Front Cover: adım 6, 2 resimden 1. Disassembling Nokia 2366i Front Cover: adım 6, 2 resimden 2.
    • Run the spudger all along the crease while lifting up.
    • Separate the front cover from the front base.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kristen
187 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 1-14, Amido Winter 2011 Cal Poly, Team 1-14, Amido Winter 2011 üyesi
CPSU-AMIDO-W11S1G14
5 Üyeler
17 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 1,336
