Ana içeriğe geç
Disassembling Nokia 2366i Front Display
Neye ihtiyacın var
    1. Disassembling Nokia 2366i Front Display, Battery: adım 1, 2 resimden 1. Disassembling Nokia 2366i Front Display, Battery: adım 1, 2 resimden 2.
      • Turn off the phone.
      • Position the phone so that the back side is in view.
      FixBot'a Sor
      Yorum Ekle
    2. Disassembling Nokia 2366i Front Display: adım 2, 1 resimden 1.
      • Apply pressure on the cover while simultaneously sliding the cover downward.
      • Remove the back battery cover.
      FixBot'a Sor
      Yorum Ekle
    3. Disassembling Nokia 2366i Front Display: adım 3, 3 resimden 1. Disassembling Nokia 2366i Front Display: adım 3, 3 resimden 2. Disassembling Nokia 2366i Front Display: adım 3, 3 resimden 3.
      • Insert the spudger between the base of the phone and the phone battery.
      • Position the phone so that the battery won't fall out of the phone.
      • Carefully lift the battery out of the phone.
      • The battery lifts out of the phone easily.
      FixBot'a Sor
      Yorum Ekle
    1. Disassembling Nokia 2366i Front Display, Front Cover: adım 4, 1 resimden 1.
      • Keep the phone closed.
      • Hold the phones sideways with the front cover of the phone facing up.
      FixBot'a Sor
      Yorum Ekle
    2. Disassembling Nokia 2366i Front Display: adım 5, 2 resimden 1. Disassembling Nokia 2366i Front Display: adım 5, 2 resimden 2.
      • Find the slight crease on the side that divides the display assembly in half.
      • Slowly wedge the spudger into the crease.
      • It's a little difficult to perform this step because the crease is narrow. Do not rush because you may damage the phone
      FixBot'a Sor
      Yorum Ekle
    3. Disassembling Nokia 2366i Front Display: adım 6, 2 resimden 1. Disassembling Nokia 2366i Front Display: adım 6, 2 resimden 2.
      • Run the spudger all along the crease while lifting up.
      • Separate the front cover from the front base.
      FixBot'a Sor
      Yorum Ekle
    1. Disassembling Nokia 2366i Front Display, Main Display: adım 7, 2 resimden 1. Disassembling Nokia 2366i Front Display, Main Display: adım 7, 2 resimden 2.
      • Remove the four 5mm screws on the metal casing using the T6 Torx screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Disassembling Nokia 2366i Front Display: adım 8, 2 resimden 1. Disassembling Nokia 2366i Front Display: adım 8, 2 resimden 2.
      • Using the spudger, disconnect the green display cable.
      FixBot'a Sor
      Yorum Ekle
    3. Disassembling Nokia 2366i Front Display: adım 9, 3 resimden 1. Disassembling Nokia 2366i Front Display: adım 9, 3 resimden 2. Disassembling Nokia 2366i Front Display: adım 9, 3 resimden 3.
      • Lift the metal casing.
      • Be careful not to pull the casing too hard because it is still attached to the phone by a wire.
      • Remove the main display from under the metal casing.
      FixBot'a Sor
      Yorum Ekle
    1. Disassembling Nokia 2366i Front Display, Front Display: adım 10, 3 resimden 1. Disassembling Nokia 2366i Front Display, Front Display: adım 10, 3 resimden 2. Disassembling Nokia 2366i Front Display, Front Display: adım 10, 3 resimden 3.
      • Fold the metal casing back over.
      • Disconnect the orange front display data cable with the spudger.
      • Hold the phone so that the antenna is facing towards you.
      • Lift up and flip over the metal casing.
      FixBot'a Sor
      Yorum Ekle
    2. Disassembling Nokia 2366i Front Display: adım 11, 1 resimden 1.
      • Using your fingers, remove the front display.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Michael Machado
337 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-14, Amido Winter 2011 Cal Poly, Team 1-14, Amido Winter 2011 üyesi
CPSU-AMIDO-W11S1G14
5 Üyeler
96 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 42
Her zaman: 1,366
