Ana içeriğe geç
Disassembling Nokia 2366i Main Display
Neye ihtiyacın var
  1. Disassembling Nokia 2366i Main Display, Battery: adım 1, 2 resimden 1. Disassembling Nokia 2366i Main Display, Battery: adım 1, 2 resimden 2.
    • Turn off the phone.
    • Position the phone so that the back side is in view.
    FixBot'a Sor
    Yorum Ekle
  2. Disassembling Nokia 2366i Main Display: adım 2, 1 resimden 1.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    • Remove the back battery cover.
    FixBot'a Sor
    Yorum Ekle
  3. Disassembling Nokia 2366i Main Display: adım 3, 3 resimden 1. Disassembling Nokia 2366i Main Display: adım 3, 3 resimden 2. Disassembling Nokia 2366i Main Display: adım 3, 3 resimden 3.
    • Insert the spudger between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • Carefully lift the battery out of the phone.
    • The battery lifts out of the phone easily.
    FixBot'a Sor
    Yorum Ekle
  4. Disassembling Nokia 2366i Main Display, Front Cover: adım 4, 1 resimden 1.
    • Keep the phone closed.
    • Hold the phones sideways with the front cover of the phone facing up.
    FixBot'a Sor
    Yorum Ekle
  5. Disassembling Nokia 2366i Main Display: adım 5, 2 resimden 1. Disassembling Nokia 2366i Main Display: adım 5, 2 resimden 2.
    • Find the slight crease on the side that divides the display assembly in half.
    • Slowly wedge the spudger into the crease.
    • It's a little difficult to perform this step because the crease is narrow. Do not rush because you may damage the phone
    FixBot'a Sor
    Yorum Ekle
  6. Disassembling Nokia 2366i Main Display: adım 6, 2 resimden 1. Disassembling Nokia 2366i Main Display: adım 6, 2 resimden 2.
    • Run the spudger all along the crease while lifting up.
    • Separate the front cover from the front base.
    FixBot'a Sor
    Yorum Ekle
  7. Disassembling Nokia 2366i Main Display, Main Display: adım 7, 2 resimden 1. Disassembling Nokia 2366i Main Display, Main Display: adım 7, 2 resimden 2.
    • Remove the four 5mm screws on the metal casing using the T6 Torx screwdriver.
    FixBot'a Sor
    Yorum Ekle
  8. Disassembling Nokia 2366i Main Display: adım 8, 2 resimden 1. Disassembling Nokia 2366i Main Display: adım 8, 2 resimden 2.
    • Using the spudger, disconnect the green display cable.
    FixBot'a Sor
    Yorum Ekle
  9. Disassembling Nokia 2366i Main Display: adım 9, 3 resimden 1. Disassembling Nokia 2366i Main Display: adım 9, 3 resimden 2. Disassembling Nokia 2366i Main Display: adım 9, 3 resimden 3.
    • Lift the metal casing.
    • Be careful not to pull the casing too hard because it is still attached to the phone by a wire.
    • Remove the main display from under the metal casing.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Michael Machado
337 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-14, Amido Winter 2011 Cal Poly, Team 1-14, Amido Winter 2011 üyesi
CPSU-AMIDO-W11S1G14
5 Üyeler
36 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 33
Her zaman: 1,496
