Ana içeriğe geç
Disassembling Nokia 2366i Rear Case
Neye ihtiyacın var
  1. Disassembling Nokia 2366i Rear Case, Battery: adım 1, 2 resimden 1. Disassembling Nokia 2366i Rear Case, Battery: adım 1, 2 resimden 2.
    • Turn off the phone.
    • Position the phone so that the back side is in view.
  2. Disassembling Nokia 2366i Rear Case: adım 2, 1 resimden 1.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    • Remove the back battery cover.
  3. Disassembling Nokia 2366i Rear Case: adım 3, 3 resimden 1. Disassembling Nokia 2366i Rear Case: adım 3, 3 resimden 2. Disassembling Nokia 2366i Rear Case: adım 3, 3 resimden 3.
    • Insert the spudger between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • Carefully lift the battery out of the phone.
    • The battery lifts out of the phone easily.
  4. Disassembling Nokia 2366i Rear Case, Rear Case: adım 4, 2 resimden 1. Disassembling Nokia 2366i Rear Case, Rear Case: adım 4, 2 resimden 2.
    • Use a Phillips #00 screwdriver or your fingers to remove the rubber tabs at top back of the phone.
  5. Disassembling Nokia 2366i Rear Case: adım 5, 2 resimden 1. Disassembling Nokia 2366i Rear Case: adım 5, 2 resimden 2.
    • Remove four 5mm screws from the back of the phone using a T6 Torx screwdriver:
    • 2 screws at the bottom
    • 2 screws at the top
  6. Disassembling Nokia 2366i Rear Case: adım 6, 2 resimden 1. Disassembling Nokia 2366i Rear Case: adım 6, 2 resimden 2.
    • Rotate the phone clockwise so the edge is facing you.
    • Insert the spudger in tabs between the outer casing and the inside frame.
    • Slide the spudger upwards.
    • This will remove the rear case of the phone.
  7. Disassembling Nokia 2366i Rear Case: adım 7, 1 resimden 1.
    • The phone should now be in two different sections.
    • 1) The rear case of the phone.
    • 2) The motherboard and the rest of the phone.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jonathan Newman
495 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-14, Amido Winter 2011 Cal Poly, Team 1-14, Amido Winter 2011 üyesi
CPSU-AMIDO-W11S1G14
5 Üyeler
17 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 32
Her zaman: 1,703
