Ana içeriğe geç
Disassembling Nokia 3100b Speaker
Neye ihtiyacın var
  1. Disassembling Nokia 3100b Speaker, Battery: adım 1, 1 resimden 1.
    • Make sure your phone is turned off.
    FixBot'a Sor
    Yorum Ekle
  2. Disassembling Nokia 3100b Speaker: adım 2, 1 resimden 1.
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
    FixBot'a Sor
    Yorum Ekle
  3. Disassembling Nokia 3100b Speaker, SIM Card: adım 3, 1 resimden 1.
    • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
    FixBot'a Sor
    Yorum Ekle
  4. Disassembling Nokia 3100b Speaker: adım 4, 1 resimden 1.
    • Retrieve your SIM card.
    FixBot'a Sor
    Yorum Ekle
  5. Disassembling Nokia 3100b Speaker, Screen: adım 5, 1 resimden 1.
    • Separate the front cover from the main body of the phone.
    FixBot'a Sor
    Yorum Ekle
  6. Disassembling Nokia 3100b Speaker: adım 6, 1 resimden 1.
    • Remove the six screws along the edges of the phone.
    FixBot'a Sor
    Yorum Ekle
  7. Disassembling Nokia 3100b Speaker: adım 7, 1 resimden 1.
    • Pull the screen assembly from the base of the phone.
    FixBot'a Sor
    Yorum Ekle
  8. Disassembling Nokia 3100b Speaker: adım 8, 1 resimden 1.
    • Carefully lift the keypad portion of the screen assembly from the circuit board.
    FixBot'a Sor
    Yorum Ekle
  9. Disassembling Nokia 3100b Speaker: adım 9, 1 resimden 1.
    • Separate the screen from the circuit board.
    • Reconnect the ports during reassembly or the screen will not function properly.
    • Remember to reconnect the screen to the circuit board when reassembling!
    FixBot'a Sor
    Yorum Ekle
  10. Disassembling Nokia 3100b Speaker: adım 10, 1 resimden 1.
    • Gently push down on the screen to pop it off of the assembly.
    FixBot'a Sor
    Yorum Ekle
  11. Disassembling Nokia 3100b Speaker: adım 11, 1 resimden 1.
    • When the screen falls out the assembly, two white tabs will fall out with it.
    • When reinstalling the screen, insert the tabs with the slanted side pointing upwards so they slide into the assembly.
    FixBot'a Sor
    Yorum Ekle
  12. Disassembling Nokia 3100b Speaker, Speaker: adım 12, 1 resimden 1.
    • Set the screen and the tabs aside.
    FixBot'a Sor
    Yorum Ekle
  13. Disassembling Nokia 3100b Speaker: adım 13, 1 resimden 1.
    • You can now access the speaker.
    • Note the tab on the end of the speaker. It must be placed in correctly in order to reinstall the speaker.
    FixBot'a Sor
    Yorum Ekle
  14. Disassembling Nokia 3100b Speaker: adım 14, 1 resimden 1.
    • Remove the speaker from the assembly.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Sterling Fuentes
139 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 29-64, Johann Spring 2010 Cal Poly, Team 29-64, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S29G64
3 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 47
Her zaman: 1,596
