Ana içeriğe geç
Disassembling Nokia 3395 Inner Components
Neye ihtiyacın var
  1. Disassembling Nokia 3395 Inner Components, Back Case: adım 1, 3 resimden 1. Disassembling Nokia 3395 Inner Components, Back Case: adım 1, 3 resimden 2. Disassembling Nokia 3395 Inner Components, Back Case: adım 1, 3 resimden 3.
    • Turn the phone off.
    • Hold the phone, and gently press the white button located at the bottom of the phone.
    • While pressing the button, slide the back plate upwards, opening the plate.
    FixBot'a Sor
    Yorum Ekle
  2. Disassembling Nokia 3395 Inner Components, Battery: adım 2, 2 resimden 1. Disassembling Nokia 3395 Inner Components, Battery: adım 2, 2 resimden 2.
    • Locate grey buttons beneath battery (shown).
    • Spread buttons simultaneously away from each other and the battery will pop out.
    • Remove battery from phone.
    FixBot'a Sor
    Yorum Ekle
  3. Disassembling Nokia 3395 Inner Components, Front Case: adım 3, 2 resimden 1. Disassembling Nokia 3395 Inner Components, Front Case: adım 3, 2 resimden 2.
    • Push the two black buttons on the side with your thumbs forward. This will release the front faceplate.
    • Flip over the device, and pry the faceplate away.
    FixBot'a Sor
    Yorum Ekle
  4. Disassembling Nokia 3395 Inner Components, Screen: adım 4, 2 resimden 1. Disassembling Nokia 3395 Inner Components, Screen: adım 4, 2 resimden 2.
    • Remove six T6 screws.
    FixBot'a Sor
    Yorum Ekle
  5. Disassembling Nokia 3395 Inner Components: adım 5, 2 resimden 1. Disassembling Nokia 3395 Inner Components: adım 5, 2 resimden 2.
    • Insert spudger between screen assembly and phone body.
    • Spread apart as shown. Avoid damaging the screen assembly by removing the screen slowly.
    FixBot'a Sor
    Yorum Ekle
  6. Disassembling Nokia 3395 Inner Components, Logic Board: adım 6, 2 resimden 1. Disassembling Nokia 3395 Inner Components, Logic Board: adım 6, 2 resimden 2.
    • Remove logic board as shown.
    FixBot'a Sor
    Yorum Ekle
  7. Disassembling Nokia 3395 Inner Components, Inner Components: adım 7, 1 resimden 1.
    • Use the following legend to locate each component:
    • Microphone/power assembly.
    • Vibrating unit.
    • SIM card reader.
    • Audio speaker.
    • Power toggle button.
    • Battery connector.
    FixBot'a Sor
    Yorum Ekle
  8. Disassembling Nokia 3395 Inner Components: adım 8, 2 resimden 1. Disassembling Nokia 3395 Inner Components: adım 8, 2 resimden 2.
    • Insert spudger between power assembly/micro-phone and phone body.
    • Pry as shown and remove the power assembly/microphone.
    FixBot'a Sor
    Yorum Ekle
  9. Disassembling Nokia 3395 Inner Components: adım 9, 1 resimden 1.
    • Once located, the following components are easily removed by pulling them out with your hand.
    • Vibrating unit.
    • SIM card reader.
    • Audio speaker.
    FixBot'a Sor
    Yorum Ekle
  10. Disassembling Nokia 3395 Inner Components: adım 10, 2 resimden 1. Disassembling Nokia 3395 Inner Components: adım 10, 2 resimden 2.
    • Audio speaker.
    FixBot'a Sor
    Yorum Ekle
  11. Disassembling Nokia 3395 Inner Components: adım 11, 2 resimden 1. Disassembling Nokia 3395 Inner Components: adım 11, 2 resimden 2.
    • SIM card reader.
    FixBot'a Sor
    Yorum Ekle
  12. Disassembling Nokia 3395 Inner Components: adım 12, 2 resimden 1. Disassembling Nokia 3395 Inner Components: adım 12, 2 resimden 2.
    • Vibrating unit.
    FixBot'a Sor
    Yorum Ekle
  13. Disassembling Nokia 3395 Inner Components: adım 13, 2 resimden 1. Disassembling Nokia 3395 Inner Components: adım 13, 2 resimden 2.
    FixBot'a Sor
    Yorum Ekle
  14. Disassembling Nokia 3395 Inner Components: adım 14, 2 resimden 1. Disassembling Nokia 3395 Inner Components: adım 14, 2 resimden 2.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nico Lee
83 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 30-41, Garner Spring 2010 Cal Poly, Team 30-41, Garner Spring 2010 üyesi
CPSU-GARNER-S10S30G41
4 Üyeler
23 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 42
Her zaman: 3,374
