Ana içeriğe geç
Disassembling Nokia 3395 Logic Board
Neye ihtiyacın var
  1. Disassembling Nokia 3395 Logic Board, Back Case: adım 1, 3 resimden 1. Disassembling Nokia 3395 Logic Board, Back Case: adım 1, 3 resimden 2. Disassembling Nokia 3395 Logic Board, Back Case: adım 1, 3 resimden 3.
    • Turn the phone off.
    • Hold the phone, and gently press the white button located at the bottom of the phone.
    • While pressing the button, slide the back plate upwards, opening the plate.
  2. Disassembling Nokia 3395 Logic Board, Battery: adım 2, 2 resimden 1. Disassembling Nokia 3395 Logic Board, Battery: adım 2, 2 resimden 2.
    • Locate grey buttons beneath battery (shown).
    • Spread buttons simultaneously away from each other and the battery will pop out.
    • Remove battery from phone.
  3. Disassembling Nokia 3395 Logic Board, Front Case: adım 3, 2 resimden 1. Disassembling Nokia 3395 Logic Board, Front Case: adım 3, 2 resimden 2.
    • Push the two black buttons on the side with your thumbs forward. This will release the front faceplate.
    • Flip over the device, and pry the faceplate away.
  4. Disassembling Nokia 3395 Logic Board, Screen: adım 4, 2 resimden 1. Disassembling Nokia 3395 Logic Board, Screen: adım 4, 2 resimden 2.
    • Remove six T6 screws.
  5. Disassembling Nokia 3395 Logic Board: adım 5, 2 resimden 1. Disassembling Nokia 3395 Logic Board: adım 5, 2 resimden 2.
    • Insert spudger between screen assembly and phone body.
    • Spread apart as shown. Avoid damaging the screen assembly by removing the screen slowly.
  6. Disassembling Nokia 3395 Logic Board, Logic Board: adım 6, 2 resimden 1. Disassembling Nokia 3395 Logic Board, Logic Board: adım 6, 2 resimden 2.
    • Remove logic board as shown.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Nico Lee
83 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 30-41, Garner Spring 2010 Cal Poly, Team 30-41, Garner Spring 2010 üyesi
CPSU-GARNER-S10S30G41
4 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 10
Her zaman: 2,043
