Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
This guide will show you how to remove the logic board from the Nokia 3560.
Parçalar
Hiçbir parça belirtilmedi.
  1. Press down on the release latch on the bottom of the cover. Once the latch is released, lift the cover from the phone.
    • Press down on the release latch on the bottom of the cover.
    • Once the latch is released, lift the cover from the phone.
  2. Lift the front case off of the phone body.
    • Lift the front case off of the phone body.
  3. Lift the keypad off of the phone. Lift the keypad off of the phone.
    • Lift the keypad off of the phone.
  4. Nintendo Switch Kit'leri
    Oyuna geri dönmek için hızlı bir düzeltme
    Switch Kit'leri Satın Al
  5. The screen is held to the body by six screws.
    • The screen is held to the body by six screws.
  6. Unscrew the six screws with a Torx screwdriver (six-pointed star shaped bit).
    • Unscrew the six screws with a Torx screwdriver (six-pointed star shaped bit).
  7. Insert a flat screwdriver between the black body and plastic layer. Insert a flat screwdriver between the black body and plastic layer.
    • Insert a flat screwdriver between the black body and plastic layer.
  8. Pry the layers apart. The LCD and plastic layer will lift out as one piece.
    • Pry the layers apart. The LCD and plastic layer will lift out as one piece.
  9. With the screws removed, the logic board can then be lifted out of the body by hand.
    • With the screws removed, the logic board can then be lifted out of the body by hand.
Sonuç
Sam Ryan
1 İtibar
8 adet Kılavuz yazıldı
Takım
Cal Poly, Team 30-39, Garner Spring 2010 Cal Poly, Team 30-39, Garner Spring 2010 üyesi
CPSU-GARNER-S10S30G39
5 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,763
