Ana içeriğe geç
Disassembling Nokia 3560 Microphone
Neye ihtiyacın var
  1. Disassembling Nokia 3560 Microphone, Back Cover: adım 1, 2 resimden 1. Disassembling Nokia 3560 Microphone, Back Cover: adım 1, 2 resimden 2.
    • Press down on the release latch on the bottom of the cover.
    • Once the latch is released, lift the cover from the phone.
  2. Disassembling Nokia 3560 Microphone, Disassembling Nokia 3560 Keypad: adım 2, 1 resimden 1.
    • Lift the front case off of the phone body.
  3. Disassembling Nokia 3560 Microphone: adım 3, 2 resimden 1. Disassembling Nokia 3560 Microphone: adım 3, 2 resimden 2.
    • Lift the keypad off of the phone.
  4. Disassembling Nokia 3560 Microphone, Disassembling Nokia 3560 LCD Display: adım 4, 1 resimden 1.
    • The screen is held to the body by six screws.
  5. Disassembling Nokia 3560 Microphone: adım 5, 1 resimden 1.
    • Unscrew the six screws with a Torx screwdriver (six-pointed star shaped bit).
  6. Disassembling Nokia 3560 Microphone: adım 6, 2 resimden 1. Disassembling Nokia 3560 Microphone: adım 6, 2 resimden 2.
    • Insert a flat screwdriver between the black body and plastic layer.
  7. Disassembling Nokia 3560 Microphone: adım 7, 1 resimden 1.
    • Pry the layers apart. The LCD and plastic layer will lift out as one piece.
  8. Disassembling Nokia 3560 Microphone, Disassembling Nokia 3560 Logic Board: adım 8, 1 resimden 1.
    • With the screws removed, the logic board can then be lifted out of the body by hand.
  9. Disassembling Nokia 3560 Microphone, Microphone: adım 9, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use tweezers to securely grip the microphone, then pull.
    • Be careful not to remove the metal prongs.
Sonuç
Sam Ryan
37 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 30-39, Garner Spring 2010 Cal Poly, Team 30-39, Garner Spring 2010 üyesi
CPSU-GARNER-S10S30G39
5 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 60
Her zaman: 2,211
