Ana içeriğe geç
Disassembling Nokia 6086 Base of The Phone
  1. Disassembling Nokia 6086 Base of The Phone, Battery: adım 1, 1 resimden 1.
    • Turn off the phone.
    • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
    • Position the phone so that the back side is in view.
  2. Disassembling Nokia 6086 Base of The Phone: adım 2, 3 resimden 1. Disassembling Nokia 6086 Base of The Phone: adım 2, 3 resimden 2. Disassembling Nokia 6086 Base of The Phone: adım 2, 3 resimden 3.
    • Remove the back battery cover.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
  3. Disassembling Nokia 6086 Base of The Phone: adım 3, 3 resimden 1. Disassembling Nokia 6086 Base of The Phone: adım 3, 3 resimden 2. Disassembling Nokia 6086 Base of The Phone: adım 3, 3 resimden 3.
    • Insert the iPod opening tool between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • The battery lifts out of the phone fast and easily.
    • Carefully lift the battery out of the phone.
  4. Disassembling Nokia 6086 Base of The Phone, Upper Back Cover: adım 4, 1 resimden 1.
    • Turn the phone so that the back of the phone is facing forward.
    • The picture to the left shows the location of the plastic tabs that attach to the upper cover of the phone.
    • In this picture, the upper cover has already been removed.
  5. Disassembling Nokia 6086 Base of The Phone: adım 5, 2 resimden 1. Disassembling Nokia 6086 Base of The Phone: adım 5, 2 resimden 2.
    • Place the iPod opening tool under the tabs near the top of the phone.
    • Slide the iPod Opening Tool upwards.
    • This will pop the tabs and release the upper part of the phone.
    • Repeat for the left and the right sides.
  6. Disassembling Nokia 6086 Base of The Phone: adım 6, 2 resimden 1. Disassembling Nokia 6086 Base of The Phone: adım 6, 2 resimden 2.
    • Place the iPod opening tool at the top area of the bottom section of the phone (indicated in picture).
    • Lift the iPod opening tool to pop open the clips.
    • This will release the upper back cover of the phone.
  7. Disassembling Nokia 6086 Base of The Phone: adım 7, 3 resimden 1. Disassembling Nokia 6086 Base of The Phone: adım 7, 3 resimden 2. Disassembling Nokia 6086 Base of The Phone: adım 7, 3 resimden 3.
    • Push upward on the top back cover using two thumbs.
    • This will remove the top back cover from the phone.
  8. Disassembling Nokia 6086 Base of The Phone, Base of The Phone: adım 8, 2 resimden 1. Disassembling Nokia 6086 Base of The Phone, Base of The Phone: adım 8, 2 resimden 2.
    • Locate the four screws.
    • Remove the screws using a T6 Torx screwdriver.
  9. Disassembling Nokia 6086 Base of The Phone: adım 9, 2 resimden 1. Disassembling Nokia 6086 Base of The Phone: adım 9, 2 resimden 2.
    • Turn the phone over.
    • Gently pull apart the phone.
    • Start at the bottom of the phone and pull outward.
    • There are plastic catches on the middle of each side. These should pop free as you pull.
    • Be careful, the phone will separate into two sections.
  10. Disassembling Nokia 6086 Base of The Phone: adım 10, 2 resimden 1. Disassembling Nokia 6086 Base of The Phone: adım 10, 2 resimden 2.
    • The phone should now be in two different sections.
    • 1) The logic board and the back cover
    • 2) The keypad and the rest of the phone
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Andrea
70 İtibar
5 adet Kılavuz yazıldı
Cal Poly, Team 26-30, Regan Spring 2010 Cal Poly, Team 26-30, Regan Spring 2010 üyesi
CPSU-REGAN-S10S26G30
4 Üyeler
17 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 3,578
