Ana içeriğe geç
Disassembling Nokia 6086 Top Front Cover
Neye ihtiyacın var
  1. Disassembling Nokia 6086 Top Front Cover, Battery: adım 1, 1 resimden 1.
    • Turn off the phone.
    • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
    • Position the phone so that the back side is in view.
  2. Disassembling Nokia 6086 Top Front Cover: adım 2, 3 resimden 1. Disassembling Nokia 6086 Top Front Cover: adım 2, 3 resimden 2. Disassembling Nokia 6086 Top Front Cover: adım 2, 3 resimden 3.
    • Remove the back battery cover.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
  3. Disassembling Nokia 6086 Top Front Cover: adım 3, 3 resimden 1. Disassembling Nokia 6086 Top Front Cover: adım 3, 3 resimden 2. Disassembling Nokia 6086 Top Front Cover: adım 3, 3 resimden 3.
    • Insert the iPod opening tool between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • The battery lifts out of the phone fast and easily.
    • Carefully lift the battery out of the phone.
  4. Disassembling Nokia 6086 Top Front Cover, Top Front Cover: adım 4, 1 resimden 1.
    • Close the phone.
    • Face the front cover forward.
  5. Disassembling Nokia 6086 Top Front Cover: adım 5, 2 resimden 1. Disassembling Nokia 6086 Top Front Cover: adım 5, 2 resimden 2.
    • Locate the 4.5 mm notch at the top of the phone.
    • Place the iPod opening tool into the opening.
    • Slightly prop up the top section by lifting the tool.
  6. Disassembling Nokia 6086 Top Front Cover: adım 6, 3 resimden 1. Disassembling Nokia 6086 Top Front Cover: adım 6, 3 resimden 2. Disassembling Nokia 6086 Top Front Cover: adım 6, 3 resimden 3.
    • Wedge the iPod opening tool between the top cover and the phone.
    • Gently lift the top cover away from the phone using the iPod opening tool.
    • This unlatches each hook that connects the top cover to the phone.
    • Repeat for both the left and the right sides of the phone.
    • Place the top cover aside once the top cover is completely disconnected from the phone.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andrea
70 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 26-30, Regan Spring 2010 Cal Poly, Team 26-30, Regan Spring 2010 üyesi
CPSU-REGAN-S10S26G30
4 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 25
Her zaman: 2,440
