Giriş
This guides you through removing the keypad.
Parçalar
Hiçbir parçaya gerek yok.
  1. Apply pressure to the battery casing (below the camera) with your thumb and pull towards the bottom of the phone. Lift the battery case off of the phone.
    • Apply pressure to the battery casing (below the camera) with your thumb and pull towards the bottom of the phone.
    • Lift the battery case off of the phone.
  2. Gently pull the battery out of the phone, using your thumb to apply pressure to the battery at the bottom of the phone. The battery should lift out with minimal resistance. The battery should lift out with minimal resistance.
    • Gently pull the battery out of the phone, using your thumb to apply pressure to the battery at the bottom of the phone.
    • The battery should lift out with minimal resistance.
  3. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  4. Locate the notch on the bottom right corner of the phone. Beginning at this point, slide the head of the screwdriver between the front casing and the rest of the phone. Continue to slide the screwdriver towards the top edge of the phone.
    • Locate the notch on the bottom right corner of the phone.
    • Beginning at this point, slide the head of the screwdriver between the front casing and the rest of the phone.
    • Continue to slide the screwdriver towards the top edge of the phone.
    • The front casing should eventually pop off.
  5. With the front casing removed, the keypad can easily be pulled off the back of the front casing.
    • With the front casing removed, the keypad can easily be pulled off the back of the front casing.
    • In all probability, it will already have fallen out and no removal is required.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Erik Lindahl
48 İtibar
4 adet Kılavuz yazıldı
Takım
Cal Poly, Team 10-46, Garner Spring 2010 Cal Poly, Team 10-46, Garner Spring 2010 üyesi
CPSU-GARNER-S10S10G46
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 2
Her zaman: 871
