Giriş
This guides you through removing the keypad.
Neye ihtiyacın var
Using your thumb, apply pressure to the battery casing (below the camera). Firmly pull towards the bottom of the phone.
Lift the battery case off of the phone.
Insert a spudger into the indention on the bottom right side of the device.
Slide the spudger upward to a second indention at the top of the phone.
The front casing will detach from the phone.
With the front casing removed, the keypad can easily be pulled off the back of the front casing.
In all probability, it will already have fallen out and no removal is required.
Bir başkası bu kılavuzu tamamladı.
