Ana içeriğe geç
Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly
Neye ihtiyacın var
  1. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly, Battery: adım 1, 2 resimden 1. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly, Battery: adım 1, 2 resimden 2.
    • Press the button on the bottom of the rear cover.
    • Keep the button pressed while pulling the cover downward to remove the back cover.
    • Lift the cover off.
  2. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: adım 2, 1 resimden 1.
    • To remove the battery, push it down from the top and pull it out.
  3. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly, Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: adım 3, 1 resimden 1.
    • Grip the front cover from the bottom.
  4. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: adım 4, 1 resimden 1.
    • Lift the front cover off.
  5. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: adım 5, 1 resimden 1.
    • Remove the six screws using a T6 torx screwdriver.
  6. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: adım 6, 1 resimden 1.
    • Insert spudger along edge of assembly and gently lift assembly away from case
  7. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: adım 7, 1 resimden 1.
    • Remove assembly from phone
Sonuç
Colby Leslie
1 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 22-3, Maness Fall 2010 Cal Poly, Team 22-3, Maness Fall 2010 üyesi
CPSU-MANESS-F10S22G3
4 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,055
