Ana içeriğe geç
Nokia E61i Connector Housing Replacement
Neye ihtiyacın var
  1. Nokia E61i Connector Housing Replacement, Battery: adım 1, 2 resimden 1. Nokia E61i Connector Housing Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the back cover to access the battery. Press the tab on the bottom of the cover.
    • Slide the back cover downwards off of the phone while pressing the tab down.
  2. Nokia E61i Connector Housing Replacement: adım 2, 1 resimden 1.
    • Locate the bottom-left corner of the phone where there is a spot to remove the battery.
  3. Nokia E61i Connector Housing Replacement: adım 3, 1 resimden 1.
    • Lift the battery out using your finger.
    • The E61i uses a Nokia BP-4L standard battery.
  4. Nokia E61i Connector Housing Replacement, Front Cover: adım 4, 2 resimden 1. Nokia E61i Connector Housing Replacement, Front Cover: adım 4, 2 resimden 2.
    • Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
  5. Nokia E61i Connector Housing Replacement: adım 5, 1 resimden 1.
    • Remove the cover by pulling it up and off.
  6. Nokia E61i Connector Housing Replacement, Display: adım 6, 2 resimden 1. Nokia E61i Connector Housing Replacement, Display: adım 6, 2 resimden 2.
    • Take off the casing and keyboard.
    • Remove the screws while holding the screen in place using a Torx T6 screwdriver.
    • Remove the single screw while holding the screen in place using a Torx T5 screwdriver.
    • Lift the ribbon off of the contact with the motherboard.
    • Firmly press the contacts into place to connect the ribbon and the motherboard when reassembling.
  7. Nokia E61i Connector Housing Replacement: adım 7, 2 resimden 1. Nokia E61i Connector Housing Replacement: adım 7, 2 resimden 2.
    • Gently pull the screen off of the phone.
    • Be sure not to rip the sticker that connects the display and the motherboard.
    • Pull the silver case off to completely free the cracked or damaged screen.
  8. Nokia E61i Connector Housing Replacement, Motherboard: adım 8, 3 resimden 1. Nokia E61i Connector Housing Replacement, Motherboard: adım 8, 3 resimden 2. Nokia E61i Connector Housing Replacement, Motherboard: adım 8, 3 resimden 3.
    • Pull the green motherboard from the back casing.
  9. Nokia E61i Connector Housing Replacement, Connector Housing: adım 9, 1 resimden 1.
    • Remove the connector housing by pushing and sliding it off the back panel.
    • Be very careful not to lose the small loose spring from behind the button or the small button itself.
Sonuç
Christopher Patton
208 İtibar
12 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-63, Walters Spring 2011 Cal Poly, Team 9-63, Walters Spring 2011 üyesi
CPSU-WALTERS-S11S9G63
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 15
Her zaman: 2,130
