Ana içeriğe geç
Disassembling Nokia E61i Keyboard
Neye ihtiyacın var
  1. Disassembling Nokia E61i Keyboard, Battery: adım 1, 2 resimden 1. Disassembling Nokia E61i Keyboard, Battery: adım 1, 2 resimden 2.
    • First, gather all necessary tools.
    • Remove the back cover to access the battery by pushing the tab on the bottom of the cover.
    • Slide the back cover downwards off of the phone while pressing down on the tab.
    FixBot'a Sor
  2. Disassembling Nokia E61i Keyboard: adım 2, 1 resimden 1.
    • Locate the bottom-left corner of the phone where there is a spot to remove the battery.
    FixBot'a Sor
  3. Disassembling Nokia E61i Keyboard: adım 3, 1 resimden 1.
    • Lift the battery out using your finger.
    • The E61i uses a Nokia BP-4L standard battery.
    FixBot'a Sor
  4. Disassembling Nokia E61i Keyboard, Front Cover: adım 4, 2 resimden 1. Disassembling Nokia E61i Keyboard, Front Cover: adım 4, 2 resimden 2.
    • To remove the top of the back cover, pry the sides and pop it off.
    • Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
    FixBot'a Sor
  5. Disassembling Nokia E61i Keyboard: adım 5, 1 resimden 1.
    • Remove the cover by pulling it up and off.
    FixBot'a Sor
  6. Disassembling Nokia E61i Keyboard, Keyboard: adım 6, 1 resimden 1.
    • Once the front cover has been removed, there is nothing holding the keyboard to the rest of the phone. Simply remove the keyboard from the cover by lifting the keyboard from its interior side.
    FixBot'a Sor
Sonuç
Christopher Patton
208 İtibar
12 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-63, Walters Spring 2011 Cal Poly, Team 9-63, Walters Spring 2011 üyesi
CPSU-WALTERS-S11S9G63
5 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 64
Her zaman: 2,018
