Ana içeriğe geç
Disassembling Nokia E61i Volume Control Buttons
Neye ihtiyacın var
  1. Disassembling Nokia E61i Volume Control Buttons, Battery: adım 1, 2 resimden 1. Disassembling Nokia E61i Volume Control Buttons, Battery: adım 1, 2 resimden 2.
    • Remove the back cover to access the battery. Press the tab on the bottom of the cover.
    • Slide the back cover downwards off of the phone while pressing the tab down.
  2. Disassembling Nokia E61i Volume Control Buttons: adım 2, 1 resimden 1.
    • Locate the bottom-left corner of the phone where there is a spot to remove the battery.
  3. Disassembling Nokia E61i Volume Control Buttons: adım 3, 1 resimden 1.
    • Lift the battery out using your finger.
    • The E61i uses a Nokia BP-4L standard battery.
  4. Disassembling Nokia E61i Volume Control Buttons, Front Cover: adım 4, 2 resimden 1. Disassembling Nokia E61i Volume Control Buttons, Front Cover: adım 4, 2 resimden 2.
    • Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
  5. Disassembling Nokia E61i Volume Control Buttons: adım 5, 1 resimden 1.
    • Remove the cover by pulling it up and off.
  6. Disassembling Nokia E61i Volume Control Buttons, Display: adım 6, 2 resimden 1. Disassembling Nokia E61i Volume Control Buttons, Display: adım 6, 2 resimden 2.
    • Take off the casing and keyboard.
    • Remove the screws while holding the screen in place using a Torx T6 screwdriver.
    • Remove the single screw while holding the screen in place using a Torx T5 screwdriver.
    • Lift the ribbon off of the contact with the motherboard.
    • Firmly press the contacts into place to connect the ribbon and the motherboard when reassembling.
  7. Disassembling Nokia E61i Volume Control Buttons: adım 7, 2 resimden 1. Disassembling Nokia E61i Volume Control Buttons: adım 7, 2 resimden 2.
    • Gently pull the screen off of the phone.
    • Be sure not to rip the sticker that connects the display and the motherboard.
    • Pull the silver case off to completely free the cracked or damaged screen.
  8. Disassembling Nokia E61i Volume Control Buttons, Motherboard: adım 8, 3 resimden 1. Disassembling Nokia E61i Volume Control Buttons, Motherboard: adım 8, 3 resimden 2. Disassembling Nokia E61i Volume Control Buttons, Motherboard: adım 8, 3 resimden 3.
    • Pull the green motherboard from the back casing.
  9. Disassembling Nokia E61i Volume Control Buttons, Volume Control Buttons: adım 9, 1 resimden 1.
    • The volume control buttons are secured to the frame only by their fit around a small piece of the plastic. Using a small flat-head screwdriver or other flat object, lift the ribbon over this piece of the cover.
  10. Disassembling Nokia E61i Volume Control Buttons: adım 10, 1 resimden 1.
    • Next, remove the volume control buttons from the cover by pushing or pulling them out away from the interior of the cover.
Sonuç
Christopher Patton
208 İtibar
12 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-63, Walters Spring 2011 Cal Poly, Team 9-63, Walters Spring 2011 üyesi
CPSU-WALTERS-S11S9G63
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 15
Her zaman: 1,623
