Ana içeriğe geç
Disassembling Nokia X2-00
Neye ihtiyacın var
  1. Disassembling Nokia X2-00, Nokia X2-00 Background Info: adım 1, 1 resimden 1.
    • it's a cheap low-end Music Phone
    • mine got wet so i decided to clean it up and look inside!
    FixBot'a Sor
    Yorum Ekle
  2. Disassembling Nokia X2-00, Removing the Battery: adım 2, 3 resimden 1. Disassembling Nokia X2-00, Removing the Battery: adım 2, 3 resimden 2. Disassembling Nokia X2-00, Removing the Battery: adım 2, 3 resimden 3.
    • Flip it and pull the tab
    • the metal part should jump right off
    • after that remove the battery and sim card
    FixBot'a Sor
    Yorum Ekle
  3. Disassembling Nokia X2-00, Diging In!: adım 3, 1 resimden 1.
    • so i was kinda !#^&@@ off becouse there were no screws!
    • so i tryed to remove the screen protection, and it worked!
    • 1. i did break it
    • 2. there were no screws
    • just don't do that unless you need
    FixBot'a Sor
    Yorum Ekle
  4. Disassembling Nokia X2-00, Diging In! 2nd attemp!: adım 4, 2 resimden 1. Disassembling Nokia X2-00, Diging In! 2nd attemp!: adım 4, 2 resimden 2.
    • i tried to remove the side panels but that didn't work so i tried on top and it did work (Jimmy worked fine)
    • these clips kind of suck ....it takes lot of force to unclip these )
    • after you unclip it you get that piece
    FixBot'a Sor
    Yorum Ekle
  5. Disassembling Nokia X2-00, Removing the midframe: adım 5, 3 resimden 1. Disassembling Nokia X2-00, Removing the midframe: adım 5, 3 resimden 2. Disassembling Nokia X2-00, Removing the midframe: adım 5, 3 resimden 3.
    • remove these 2 TR6 Screws (mine were a bit blue)
    • open it up (clips on the bottom)
    • i was on Beast-Mode on these annying clips that held like gorilla
    FixBot'a Sor
    Yorum Ekle
  6. Disassembling Nokia X2-00, Removing the display: adım 6, 3 resimden 1. Disassembling Nokia X2-00, Removing the display: adım 6, 3 resimden 2. Disassembling Nokia X2-00, Removing the display: adım 6, 3 resimden 3.
    • Remove the 4 TR6 Screws
    • They are diffrent from the last ones !!! (this one on the right)
    • remove the whole PCB and remove the clips from the display and it should pop off
    FixBot'a Sor
    Yorum Ekle
  7. Disassembling Nokia X2-00, The Display: adım 7, 2 resimden 1. Disassembling Nokia X2-00, The Display: adım 7, 2 resimden 2.
    • it's TFT 2.2" 240x320 182 ppi Display
    FixBot'a Sor
    Yorum Ekle
  8. Disassembling Nokia X2-00, The main PCB: adım 8, 1 resimden 1.
    • anything shiehielded ...and non-replacable ...i don't like that one at all
    • sorry guys i have forgott to make photo of the backside :(
    FixBot'a Sor
    Yorum Ekle
  9. Disassembling Nokia X2-00, Extra - Mastery pieces & Test: adım 9, 2 resimden 1. Disassembling Nokia X2-00, Extra - Mastery pieces & Test: adım 9, 2 resimden 2.
    • extra steps that you don't need to do
    • 2 of those fell of and i have NO idea where from (and i don't even care)
    • i cleaned it up and powered it up and it works (just make sure you don't short anything)
    FixBot'a Sor
    Yorum Ekle
  10. Disassembling Nokia X2-00, The END: adım 10, 1 resimden 1.
    • i don't really like that one becouse it's hard to open and easy to crack plastics
    • but you can replace many things (not anything)
    • i would like USB on doughterboard and less shielding
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
10 farklı kişi bu kılavuzu tamamladı.
Mateusz
1.525 İtibar
2 adet Kılavuz yazıldı
1Rehber Yorum
Well done,come on
Segmenttopten - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 57
Her zaman: 6,043
