Ana içeriğe geç
Disassembling Numark TT1600 Circuit board
Neye ihtiyacın var
  1. Disassembling Numark TT1600 Circuit board, Circuit board: adım 1, 2 resimden 1. Disassembling Numark TT1600 Circuit board, Circuit board: adım 1, 2 resimden 2.
    • Flip over the turntable and remove the nine screws on the outer edges.
  2. Disassembling Numark TT1600 Circuit board: adım 2, 1 resimden 1.
    • Remove the back cover by pulling it apart.
  3. Disassembling Numark TT1600 Circuit board: adım 3, 1 resimden 1.
    • Locate the largest circuit board inside the device.
  4. Disassembling Numark TT1600 Circuit board: adım 4, 1 resimden 1.
    • Locate the wires that are plugged into the side of the circuit board.
  5. Disassembling Numark TT1600 Circuit board: adım 5, 2 resimden 1. Disassembling Numark TT1600 Circuit board: adım 5, 2 resimden 2.
    • Gently pull out the wires plugged into the circuit board.
  6. Disassembling Numark TT1600 Circuit board: adım 6, 2 resimden 1. Disassembling Numark TT1600 Circuit board: adım 6, 2 resimden 2.
    • Once the wires are unplugged you will notice two more wires plugged into the bottom of the circuit board.
    • Note that these wires are soldered onto the circuit, indicated by the red markers.
    • To completely remove the circuit board these wires must be removed.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sukhjinder
17 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 17-14, Regan Fall 2011 Cal Poly, Team 17-14, Regan Fall 2011 üyesi
CPSU-REGAN-F11S17G14
4 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 1,590
