Ana içeriğe geç
Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017)
Neye ihtiyacın var
  1. Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Recommended Tools: adım 1, 2 resimden 1. Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Recommended Tools: adım 1, 2 resimden 2.
    • Plastic spudgers/opening tools
    • T2 Torx Screwdriver
    FixBot'a Sor
    Yorum Ekle
  2. Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Removing the battery compartment: adım 2, 1 resimden 1.
    • Use a narrow-tipped object (such as a ballpoint pen or the tip of the T2 Torx Screwdriver) to depress the dimple on the battery compartment to release it
    • Replacement batteries are two (2) CR 2032 coin cell batteries.
    FixBot'a Sor
    Yorum Ekle
  3. Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Removing the front face: adım 3, 2 resimden 1. Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Removing the front face: adım 3, 2 resimden 2.
    • Gently pry along the edges of the remote using your fingers and prying tools to release the plastic clips.
    • It works best to start from the battery compartment and slowly work your way up to the top of the remote where the IR blaster is located.
    • Once the plastic clips are released, there is adhesive along the length of the volume sensor bar holding the front face in place. Slowly pry the face away from the rest of the remote and adjust your grip to avoid snapping the thin plastic face.
    FixBot'a Sor
    Yorum Ekle
  4. Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Removing the mainboard: adım 4, 2 resimden 1. Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Removing the mainboard: adım 4, 2 resimden 2.
    • There are (6) T2 Torx screws holding the mainboard to the frame of the remote.
    • Two clips hold the mainboard in place. Slightly lift the top of the mainboard up and slide it towards the top of the remote to remove it from the frame.
    FixBot'a Sor
    Yorum Ekle
  5. Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Disassembled: adım 5, 2 resimden 1. Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Disassembled: adım 5, 2 resimden 2.
    • The remote should now be fully disassembled.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Skeven
152 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 53
Her zaman: 507
