Ana içeriğe geç
Disassembling Olympus FE-170 Casing
Neye ihtiyacın var
  1. Disassembling Olympus FE-170 Casing, Casing: adım 1, 2 resimden 1. Disassembling Olympus FE-170 Casing, Casing: adım 1, 2 resimden 2.
    • Remove the 2 exposed screws on opposite sides of the camera. Turn the screws counter-clockwise to remove.
  2. Disassembling Olympus FE-170 Casing: adım 2, 2 resimden 1. Disassembling Olympus FE-170 Casing: adım 2, 2 resimden 2.
    • Open the battery compartment and remove the 2 screws in the top of the opening.
  3. Disassembling Olympus FE-170 Casing: adım 3, 2 resimden 1. Disassembling Olympus FE-170 Casing: adım 3, 2 resimden 2.
    • Remove the 2 exposed screws on the bottom of the camera.
  4. Disassembling Olympus FE-170 Casing: adım 4, 1 resimden 1.
    • Uncover the mini-usb dock on the side of the camera and unscrew the screw next to the flap joint
  5. Disassembling Olympus FE-170 Casing: adım 5, 1 resimden 1.
    • Uncover the video cable port on the side of the camera and remove the screw
  6. Disassembling Olympus FE-170 Casing: adım 6, 2 resimden 1. Disassembling Olympus FE-170 Casing: adım 6, 2 resimden 2.
    • Carefully slip the head of the plastic opening tool under the panels by finding the crack between the panels. Lightly apply pressure in the shown places at the top and bottom of the camera.
  7. Disassembling Olympus FE-170 Casing: adım 7, 2 resimden 1. Disassembling Olympus FE-170 Casing: adım 7, 2 resimden 2.
    • Loosen the panels on the sides of the camera in the shown places by slipping the plastic opening tool in the crack between the panels. Lightly apply pressure.
  8. Disassembling Olympus FE-170 Casing: adım 8, 2 resimden 1. Disassembling Olympus FE-170 Casing: adım 8, 2 resimden 2.
    • Ensure that the panels have been loosened. Carefully use hands to pull back and remove the panels.
Sonuç
CCrane
201 İtibar
2 adet Kılavuz yazıldı
Ekip
Baylor, Team 6-4, Shaver Spring 2015 Baylor, Team 6-4, Shaver Spring 2015 üyesi
BU-SHAVER-S15S6G4
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 640
