Parçalar
Hiçbir parçaya gerek yok.
  1. Unscrew the bottom and right side panel screws using a #00 screwdriver. (5 screws) Unscrew the bottom and right side panel screws using a #00 screwdriver. (5 screws)
    • Unscrew the bottom and right side panel screws using a #00 screwdriver. (5 screws)
  2. Remove the right side panel by pulling off the large silver piece.
    • Remove the right side panel by pulling off the large silver piece.
  3. Unscrew the remaining side and front panel screws using a #00 screwdriver. (3 screws) Unscrew the remaining side and front panel screws using a #00 screwdriver. (3 screws)
    • Unscrew the remaining side and front panel screws using a #00 screwdriver. (3 screws)
  4. Using your thumb and forefinger, pull off the silver name plate and silver "T-shape" piece. (2 pieces)
    • Using your thumb and forefinger, pull off the silver name plate and silver "T-shape" piece. (2 pieces)
  5. Remove the black front panel by sliding it towards the lens and then pulling it up off the camera.
    • Remove the black front panel by sliding it towards the lens and then pulling it up off the camera.
  6. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  7. Remove 3 screws from the front of the camera using a #00 screwdriver. Lift the two tabs to separate the case using a spudger. (one tab on top and one tab on the right side) Lift the two tabs to separate the case using a spudger. (one tab on top and one tab on the right side)
    • Remove 3 screws from the front of the camera using a #00 screwdriver.
    • Lift the two tabs to separate the case using a spudger. (one tab on top and one tab on the right side)
  8. Using a plastic spudger, lift up the black clips. Still using the plastic spudger, detach the gold connector strip and white connector strip. Using both hands, pull the camera apart into two pieces.
    • Using a plastic spudger, lift up the black clips.
    • Still using the plastic spudger, detach the gold connector strip and white connector strip.
    • Using both hands, pull the camera apart into two pieces.
  9. Using a plastic spudger, lift up the black clips. Still using the spudger, detach the 3 gold wire tape connectors from the inside of the camera.
    • Still using the spudger, detach the 3 gold wire tape connectors from the inside of the camera.
  10. Remove 3 screws from the inside of the camera using a #00 screwdriver.
    • Remove 3 screws from the inside of the camera using a #00 screwdriver.
  11. Using your thumb and forefinger, pull the lens piece straight out from the body of the camera. Using your thumb and forefinger, pull the lens piece straight out from the body of the camera.
    • Using your thumb and forefinger, pull the lens piece straight out from the body of the camera.
  12. Unscrew two screws on the right side of the camera using a #00 screwdriver.
    • Unscrew two screws on the right side of the camera using a #00 screwdriver.
  13. Using a plastic spudger, lift up the black clips.
    • Still using the spudger, detach the gold wire tape connectors from the logic board.
  14. Unsolder the upper right and lower left wires to remove logic board.
    • Unsolder the upper right and lower left wires to remove logic board.
  15. In order to remove the logic board, grab each side of it and pull up using your thumb and forefinger. In order to remove the logic board, grab each side of it and pull up using your thumb and forefinger.
    • In order to remove the logic board, grab each side of it and pull up using your thumb and forefinger.
Sonuç
Max McIntyre
511 İtibar
4 adet Kılavuz yazıldı
Takım
Cal Poly, Team 13-4, Forte Winter 2011 Cal Poly, Team 13-4, Forte Winter 2011 üyesi
CPSU-FORTE-W11S13G4
6 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 4
Her zaman: 2,977
