Ana içeriğe geç
Olympus Stylus 410 Slider Replacement
Neye ihtiyacın var
  1. Olympus Stylus 410 Slider Replacement, Slider: adım 1, 1 resimden 1.
    • Locate the 2 screws on the bottom of the slider.
    • Remove both screws with a #00 Phillips screwdriver.
  2. Olympus Stylus 410 Slider Replacement: adım 2, 1 resimden 1.
    • Gently pull on the bottom of the slider until it comes off the lower track.
    • There is a little piece that connects the slider to the track. Be sure not to lose this as it is needed to put the slider back on.
  3. Olympus Stylus 410 Slider Replacement: adım 3, 1 resimden 1.
    • Lift the slider up until it comes off the upper track.
  4. Olympus Stylus 410 Slider Replacement: adım 4, 1 resimden 1.
    • The slider should now be free from the body of the camera.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jared Ruekberg
33 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-13, Maness Spring 2010 Cal Poly, Team 6-13, Maness Spring 2010 üyesi
CPSU-MANESS-S10S6G13
5 Üyeler
17 adet Kılavuz yazıldı
2 Yorum
Camera would not turn on nor lens extend. Took slider off per instructions and cleaned the switch and was able to rotate switch back and forth to turn camera on and off by hand. Reassembled slider and could turn camera on but not off. Disassembled again and find the rotating switch is permanently stuck in counter clockwise position and cannot be activated by hand. I do not want to force the switch because it did operate very easy. What can be the trouble?
rraff8300@sbcglobal.net
Richard Rafferty - Yanıt
Excellent instructions for removing stylist 410 slider. Hope you can help with my prior stuck switch problem.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 25
Her zaman: 3,559
