Ana içeriğe geç
Disassembling Olympus Stylus 725 SW Back Panel
Neye ihtiyacın var
    1. Disassembling Olympus Stylus 725 SW Back Panel, Disassembling Olympus Stylus 725 SW Battery: adım 1, 2 resimden 1. Disassembling Olympus Stylus 725 SW Back Panel, Disassembling Olympus Stylus 725 SW Battery: adım 1, 2 resimden 2.
      • The battery is located on the bottom of the camera.
      • Remove the battery by placing your thumb on the bottom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
      • If the battery is dead, charge it for 60-90 minutes.
      • When installing a charged battery, align the battery appropriately. The positive signs and negative should line up.
      FixBot'a Sor
      Yorum Ekle
    1. Disassembling Olympus Stylus 725 SW Back Panel, Disassembling Olympus Stylus 725 SW Back Panel: adım 2, 3 resimden 1. Disassembling Olympus Stylus 725 SW Back Panel, Disassembling Olympus Stylus 725 SW Back Panel: adım 2, 3 resimden 2. Disassembling Olympus Stylus 725 SW Back Panel, Disassembling Olympus Stylus 725 SW Back Panel: adım 2, 3 resimden 3.
      • Remove the four 3 mm long cover screws at the corners of the camera using a Phillips #00 screwdriver.
      • Remove the 2 mm long screws securing the sides of the camera which holds the back panel using a Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Disassembling Olympus Stylus 725 SW Back Panel: adım 3, 2 resimden 1. Disassembling Olympus Stylus 725 SW Back Panel: adım 3, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Be careful when removing the back cover; you will need to detach the connecting ribbons. Use tweezers if necessary.
      • Detach the ribbons using your thumb, sliding them out of their slots.
      • Set the back panel face up to keep the ribbons from touching anything.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bobby Hodges
49 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 33-71, Johann Spring 2010 Cal Poly, Team 33-71, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S33G71
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 48
Her zaman: 5,016
