Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Use this guide to remove the back panel to access the components inside.
Neye ihtiyacın var
Remove the battery by placing your thumb on the bottom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
If the battery is dead, charge it for 60-90 minutes.
Unscrew the 3mm long cover screws at the corners of the camera using a #00 Philips Screwdriver.
Unscrew the 2mm long screws securing the sides of the camera which holds the back panel. Use the same screwdriver.
