Ana içeriğe geç
Disassembling Olympus Stylus 725 SW Front Panel
Neye ihtiyacın var
  1. Disassembling Olympus Stylus 725 SW Front Panel, Disassembling Olympus Stylus 725 SW Battery: adım 1, 2 resimden 1. Disassembling Olympus Stylus 725 SW Front Panel, Disassembling Olympus Stylus 725 SW Battery: adım 1, 2 resimden 2.
    • The battery is located on the bottom of the camera.
    • Remove the battery by placing your thumb on the bottom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
    • If the battery is dead, charge it for 60-90 minutes.
    • When installing a charged battery, align the battery appropriately. The positive signs and negative should line up.
  2. Disassembling Olympus Stylus 725 SW Front Panel, Front Panel: adım 2, 3 resimden 1. Disassembling Olympus Stylus 725 SW Front Panel, Front Panel: adım 2, 3 resimden 2. Disassembling Olympus Stylus 725 SW Front Panel, Front Panel: adım 2, 3 resimden 3.
    • Remove the top screws using a 1.5 mm screwdriver.
    • Remove the single side screw located on the side of the camera where the tab is, using a #00 screwdriver.
Sonuç
Bobby Hodges
49 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 33-71, Johann Spring 2010 Cal Poly, Team 33-71, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S33G71
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 3,237
