Ana içeriğe geç
Giriş
Use this guide to remove the side panels to access parts inside.
Parçalar
Hiçbir parça belirtilmedi.
  1. The battery is located on the bottom of the camera. Remove the battery by placing your thumb on the buttom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
    • The battery is located on the bottom of the camera.
    • Remove the battery by placing your thumb on the buttom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
    • Charge the battery for 60-90 minutes if your battery is dead.
    • When installing a charged battery, align the battery appropriately, with the positive signs and negative signs lining up.
  2. Remove the top screws using a 1.5 mm screwdriver. Remove the single side screw located on the side of the camera where the tab is, using a #00 screwdriver. Remove the single side screw located on the side of the camera where the tab is, using a #00 screwdriver.
    • Remove the top screws using a 1.5 mm screwdriver.
    • Remove the single side screw located on the side of the camera where the tab is, using a #00 screwdriver.
  3. Apple Watch Kitleri
    Screen and battery repairs just got easier.
    Hemen Alışveriş Yapın
    Apple Watch Kitleri
  4. Using a #00 Philips Head Screwdriver, remove the screws located on all four sides of the camera. Using a #00 Philips Head Screwdriver, remove the screws located on all four sides of the camera. Using a #00 Philips Head Screwdriver, remove the screws located on all four sides of the camera.
    • Using a #00 Philips Head Screwdriver, remove the screws located on all four sides of the camera.
  5. After removing all four of the screws, pry the side covers off of the camera. After removing all four of the screws, pry the side covers off of the camera. After removing all four of the screws, pry the side covers off of the camera.
    • After removing all four of the screws, pry the side covers off of the camera.
Sonuç
Bobby Hodges
49 İtibar
6 adet Kılavuz yazıldı
Takım
Cal Poly, Team 33-71, Johann Spring 2010 Cal Poly, Team 33-71, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S33G71
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 2,645
