Ana içeriğe geç
Giriş
Use this guide to separate the face plate from the amplifier.
  1. Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place. Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place. Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place.
    • Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place.
  2. Remove the top screw on the back panel. Remove the top screw on the back panel.
    • Remove the top screw on the back panel.
  3. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    Hemen Alışveriş Yapın
    iPhone X Fix Kits
  4. Slide off the case to expose the internal components of the receiver. Slide off the case to expose the internal components of the receiver.
    • Slide off the case to expose the internal components of the receiver.
  5. Unscrew the three screws on top of the face plate. Unscrew the three screws on top of the face plate. Unscrew the three screws on top of the face plate.
    • Unscrew the three screws on top of the face plate.
  6. Unscrew the one screw on the bottom of the front panel. Unscrew the one screw on the bottom of the front panel.
    • Unscrew the one screw on the bottom of the front panel.
  7. Simultaneously push down on the head of the snap on each end of the device with your thumbs and push to seperate the face plate. This may take some force. Simultaneously push down on the head of the snap on each end of the device with your thumbs and push to seperate the face plate. This may take some force. Simultaneously push down on the head of the snap on each end of the device with your thumbs and push to seperate the face plate. This may take some force.
    • Simultaneously push down on the head of the snap on each end of the device with your thumbs and push to seperate the face plate. This may take some force.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ryan
90 İtibar
3 adet Kılavuz yazıldı
Takım
Cal Poly, Team 27-92, Amido Spring 2010 Cal Poly, Team 27-92, Amido Spring 2010 üyesi
CPSU-AMIDO-S10S27G92
4 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
I would like to remove Front Face plate of my Onkyo TX-SR875 AV Receiver. Please guide me how can I open it?
Ashish Solanki - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 4
Son 30 Gün: 12
Her zaman: 2,422
