Ana içeriğe geç
Disassembling Optoma HD20 Cover
Neye ihtiyacın var
  1. Disassembling Optoma HD20 Cover, Disassembling Optoma HD20 Cover: adım 1, 2 resimden 1. Disassembling Optoma HD20 Cover, Disassembling Optoma HD20 Cover: adım 1, 2 resimden 2.
    • Twist the focal cap clockwise until it is fully extended.
    • Remove the focal cap by pulling it straight out.
    FixBot'a Sor
    Yorum Ekle
  2. Disassembling Optoma HD20 Cover: adım 2, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
    FixBot'a Sor
    Yorum Ekle
  3. Disassembling Optoma HD20 Cover: adım 3, 1 resimden 1.
    • Use a plastic opening tool to gently pry the top cover off of the device.
    • It is easier to pry off the cover from the back side just above the HDMI ports.
    FixBot'a Sor
    Yorum Ekle
  4. Disassembling Optoma HD20 Cover: adım 4, 1 resimden 1.
    • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
    • Remove the ribbon by disconnecting it from the main circuit board.
    • Lift up the clip holding it down and pull the ribbon out.
    FixBot'a Sor
    Yorum Ekle
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Trever
1.282 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-23, Maness Winter 2015 Cal Poly, Team 21-23, Maness Winter 2015 üyesi
CPSU-MANESS-W15S21G23
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 40
Her zaman: 3,823
